Find Einstein's Field Equation - Intuition with Strong Equivalence Principle
  • Context: Undergrad
  • Thread starter Thread starter hugo_faurand
    Field
13 replies · 2K views
hugo_faurand
TL;DR
How do we derive field equations ?
Hello everyone !
I'm getting into General relativity. I wonder know how we find the Einstein's field equation.
Maybe we can have an intuition with the strong equivalence principle.
So if you can enlight me ☺️☺️ please
Regards
on Phys.org
It depends on what assumptions you start with. What assumptions do you want to start with?
In Misner, Thorne & Wheeler's classic textbook on GR, they describe six different ways to derive the Einstein Field Equation, from six different sets of starting assumptions.
John Baez, who has written a lot of articles for this site, has a nice formulation of this, which involves considering the deformation of a falling ball of liquid and applying various conservation laws. He arrives at the Einstein equations without the standard appeal to Riemannian geometry, which is hard to parse without background. Basically he is able to derive how the shape of a ball of matter deforms based on how much pressure the matter in the ball exerts, which is equivalent to the effect of the stress energy tensor on geodesics.
https://arxiv.org/pdf/gr-qc/0103044.pdf
How is ##F = ma## derived?
How is the equation for Newtonian gravity,
$$F = G \frac{m_1 m_2}{r^2},$$
derived?
A clarification: it's the energy density and pressure of the matter, not just the pressure.
PeterDonis said:
Chapter 4 in Sean Carroll's online lecture notes on GR [1] also describes a derivation of the Einstein Field Equation from reasonable physical principles and the requirement for correspondence with Newtonian gravity in the low speed, weak field approximation.
[1] https://arxiv.org/pdf/gr-qc/9712019.pdf
This is exactly what I needed, first I searched something like that in Tong's course but there were nothing.
Thank you !
derived?
It's not derived but found from observations and ingenious mathematical insight. The same holds of course for GR. My favorite way is the one by Hilbert, i.e., looking for the most simple generally covariant action that can be built from the metric tensor and leads to 2nd-order partial differential equations (see Landau&Lifhitz vol. 2 or Weinberg, Gravitation).
Another alternative way, which emphasizes that gravitation is an interaction and not a priori a manifestation of a pseudo-Riemannian spacetime manifold is the way how Feynman (in the "Feynman lectures on graviation") derives it. There he makes indeed use of the strong equivalence principle. Then the geometrical reinterpretation becomes a deduced property, but the calculation is somewhat lengthy compared to the action-principle approach.
You may also like to look up Nordstrom gravity. Einstein gravity is not the unique relativistic theory of gravity compatible with Newtonian gravity. So it is not possible to uniquely derive Einstein gravity on those grounds alone, since Nordstrom gravity is also a possibility. Nordstrom gravity, however, is not compatible with the observed perihelion motion of Mercury.
It also predicts zero light bending by the Sun and a much smaller Shapiro time delay than GR does.
But this is not a derivation of the field equation at all. Instead, it is an elegant description of its physical content
It also does not satisfy the strong equivalence principle when an EM wave packet is considered. Clifford Will has argued in several places that GR is the only known theory that does. See:
https://arxiv.org/pdf/1104.4608.pdf
which despite its abstract, notes the exception in footnote 2 on page 4.
Just a comment on the "derivation" issue. It is better, in my opinion, to ask how physical theories are motivated, rather than how they are derived.
The end goal is a physical theory that's consistent with experiment. Theories can be derived from certain assumed principles, but the principles that they are derived from cannot be derived, the must be assumed or postulated. Picking what assumptions to make is not an easy task, the scientific method basically suggests that we focus on those theories that match experiment.
For instance, if one wants to know how many angels can dance on the head of a pin, the scientific method says that one should count them. One might make certain assumptions about the behavior of angels, and use those assumptions and the logic of the derivations that follow from those assumptions, to predict how many angels should be able to dance on the head of a pin. But in the end it is then important that one actually goes out and counts them.
As a sub-point, it is also important that one can actually make measurements, such as counting the angels. The particular example of using angels is a bit fanciful, I suppose my motivation for using this fanciful language is to illustrate the difference between the concrete and the abstract, to remind myself and the reader that in the end one needs to focus on the concrete, that the abstract is a tool to understand the former.
