Find gravitational acceleration through luminosity
The discussion focuses on estimating the solar radius and gravitational acceleration at the sun's surface using luminosity and effective temperature. The initial approach involved substituting gravitational equations into the luminosity equation, but the results were inaccurate. After clarifying the method, participants confirmed that solving for the solar radius first and then using it to calculate gravitational acceleration yields a value approximately 30 times greater than Earth's gravity. Key assumptions include treating the sun as a black body, which may introduce discrepancies if not valid. Ultimately, the correct calculations led to a satisfactory result, affirming the method's effectiveness.
astrofunk21
Use equation 1.3 to estimate the solar radius Ro from its luminosity and effective temperature. Show that the gravitational acceleration g at the surface is about 30 times larger than that on Earth.
(1.3) L=4∏R2σSBT4
Well we know the gravity of something can be determined through g=\frac{-GM}{r*r}. Solving for r in the gravitational equation will allow us to substitute that into the luminosity equation. With all of those known, we can solve for g and see how it is 30 times larger. This however did not work. My answer was -27.79 m*s-2.
Now since this number is pretty much off by a factor of ten, I feel that I'm on the right track. Maybe I messed something up in my calculation that you guys will see. My substitution will be below if it helps.
1. L=4∏R2σSBT4
2. g=\frac{-GM}{r*r}
3. r2=\frac{-GM}{g}
4. L=4∏\frac{-GM}{g}σSBT4
5. g=\frac{-GMT^{4}4∏σ}{L}
6. Then solve for g!
Well we know the gravity of something can be determined through g=−GM/r∗r. Using this we can first find the effective temperatures for both the Earth and the sun. Solving for r in the gravitational equation will allow us to substitute that into the luminosity equation.
I'm not clear on your reasoning here - doesn;t the question expect you to do this the exact opposite way around?
Hey sorry about that, meant to delete that sentence about the effective temperature. It was a method I was using before. Does it make more sense now?
It looks to me like you solved correctly for g in terms of L, T and M. Now they must have given you some numbers to plug in for those variables. What were they?
It's the reasoning that puzzles me - wouldn't it be more direct to solve for R2 in eq. 1.3 and sub into the equation for g?
$$g_{Sol} = \frac{M_{Sol}}{m_E} \frac{r^2_{E}}{R^2_{Sol}} g_{E}\; : \; R^2=\frac{L}{4\pi\sigma T^4}$$
Anyway - you got the same equation so ... provided you have not made some arithmetic error, or used bad numbers, what does the mismatch tell you about the estimate? What assumptions are made to get equation 1.3?
In terms of some numbers that were used I had:
M = 2x1030kg
T = 5780K
σSB = 5.67x10-8Wm-2K-4
L = 3.86x1026W
G = 6.67x10-11m3kg-1s-2
Simpler problem than I thought. Got the answer and it's right.
I solved for R like the problem says and like Simon said. Then plugged that into the accel due to gravity equation. This gave me a number around 280 which is close to 30 times that of Earth's gravity.
Thanks guys!
The primary assumption is that the sun is a black body.
I had wondered if the teacher wanted to provide an example of a model that did not work well :) If the numbers were correct, and there was no finger-slippage on the calculator, then the result disagreeing with reality would mean that the model contained a flaw.
Occasionally someone will do that to you just to see who's alert.
You get marks by identifying the flaw - hence the suggestion to look at the assumptions.
But that was not the case this time.
