Find gravitational potential energy if at point
To find the gravitational potential energy at point B, the relationship between the distances from the center of the Earth to points A and B is crucial, with B being twice the distance of A. The gravitational potential energy at A is given as -2MJ, which can be expressed using the formula Eg = -G*M*m / r. By substituting the distance for B (2rA) into the potential energy formula, the potential energy at B can be derived. The algebraic manipulation confirms that the potential energy at B is -MJ, reflecting the change in distance. This approach effectively clarifies the relationship between gravitational potential energy and distance in a gravitational field.
jono240
An object is moved from A to B in the gravitational field of earth. The distance between the center of Earth and B is twice that of A. If the gravitational potential energy of the object at A is -2MJ, what is the gravitational potential energy of the object at B?
Eg = -G*M*m / r
Im stumped for where I should start. I need to find the mass or radius of orbit of this object but I can't figure out how to do that with just the gravitational potential energy given. Please help with a hint on where to start. I don't want the question answered. Thanks
If rA is the distance from the center of the Earth to A, and rb the same for B, then you know
\frac{GMm}{r_A} = -2MJ
\frac{GMm}{r_B} = ?
Use the relation between the two lengths and the first formula to get the potential energy at B.
I know that rb is 2ra
so if I just substitute the 2ra in the first equation, do I get GMm/2ra = -2MJ/2
Im not sure if that's algebraically correct
That's correct, you basically substituted the value for the potential energy at A into the expression for it at B (with the additional half factor)
lol alright. I wasnt sure about the algebra there.
thanks a lot man!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
