Find P.Q & Q.P from Permutations of X (1,2,3,4,5)
  • Context: Undergrad
  • Thread starter Thread starter FatTail
    Mapping Permutation
The discussion revolves around finding the products of two permutations, P and Q, of the set X = {1, 2, 3, 4, 5}. Participants explore the methods for calculating the compositions P.Q and Q.P, including the notation and mapping involved in permutations.
  • Post 1 introduces the problem of finding the products of two permutations and expresses difficulty in matching book answers.
  • Post 2 explains the mappings of Q and P using tables and describes the process of finding P.Q by applying Q first, then P.
  • Post 3 reiterates the mappings and emphasizes the standard convention of applying P before Q in Q.P, while also noting the importance of checking conventions with educational materials.
  • Post 4 clarifies that permutations are functions and that their product is a composition of functions, specifically P(Q(x)).
  • Post 5 indicates understanding of the explanations provided by other participants.
Participants generally agree on the methods for calculating the permutations and the notation used, but there is a note of caution regarding the conventions of applying permutations, suggesting that there may be variations in definitions.
There is an acknowledgment that the order of applying permutations may vary based on different conventions, which could lead to different interpretations of the results.
FatTail
hi
if P and Q are 2 permutations of X, their product, P.Q, is the permutation of X (X=1,2,3,4,5), obtained by following the mapping Q with the mapping P. if Q=2 3 4 1 5, and P is 1 2 5 3 4, then how do i find P.Q and Q.P ?
i have tried a few mappings but can never get the same answer as in the book :)
answer for P.Q is 2 5 3 1 4
answer for Q.P is 2 3 5 4 1
please can anyone explain the steps.
thanks
"Q=2 3 4 1 5" means that this mapping happens:
[tex] \begin{tabular}{ | c | c | c | c | c | }<br /> \hline<br /> 1 & 2 & 3 & 4 & 5 \\<br /> \Downarrow & \Downarrow & \Downarrow & \Downarrow & \Downarrow \\<br /> 2 & 3 & 4 & 1 & 5 \\ \hline<br /> \end{tabular}[/tex]
In other words:
1 gets mapped to 2,
2 gets mapped to 3,
And so on.
Similarly, "P=1 2 5 3 4" means this happens:
[tex] \begin{tabular}{ | c | c | c | c | c | }<br /> \hline<br /> 1 & 2 & 3 & 4 & 5 \\<br /> \Downarrow & \Downarrow & \Downarrow & \Downarrow & \Downarrow \\<br /> 1 & 2 & 5 & 3 & 4 \\ \hline<br /> \end{tabular}[/tex]
That is,
1 gets mapped to 1,
2 gets mapped to 2,
3 gets mapped to 5,
and so on.
So to find the product P.Q, you want to build a table like the ones above by "following the arrows". So first you need to find out what 1 gets mapped to under the product P.Q. Whenever you have a product of permutations, you work from right to the left. So you start with Q. You know that Q maps 1 to 2. And then P maps 2 to 2. So the first entry of the table is 2.
[tex] \begin{tabular}{ | c | c | c | c | c | }<br /> \hline<br /> 1 & 2 & 3 & 4 & 5 \\<br /> \Downarrow & \Downarrow & \Downarrow & \Downarrow & \Downarrow \\<br /> 2 & ? & ? & ? & ? \\ \hline<br /> \end{tabular}[/tex]
Next, you want to find out what 2 gets mapped to. Q maps 2 to 3, and P maps 3 to 5. So the second entry is a 5.
[tex] \begin{tabular}{ | c | c | c | c | c | }<br /> \hline<br /> 1 & 2 & 3 & 4 & 5 \\<br /> \Downarrow & \Downarrow & \Downarrow & \Downarrow & \Downarrow \\<br /> 2 & 5 & ? & ? & ? \\ \hline<br /> \end{tabular}[/tex]
And so on.
To find Q.P, perform the same process, but start with P.
Q= 2 3 4 1 5, if I understand your notation, would also be written
[tex]\left(\begin{array}{ccccc}1 & 2 & 3 & 4 & 5 \\ 2 & 3 & 4 & 1 & 5\end{array}\right)[/tex]
and means that 1 is changed into 2, 2 is changed into 3, 3 is changed into 4, 4 is changed into 1, and 5 is changed into itself (remains the same). P= 1 2 5 3 4 is
[tex]\left(\begin{array}{ccccc}1 & 2 & 3 & 4 & 5 \\ 1 & 2 & 5 & 3 & 4\end{array}\right)[/tex]
and means that 1 and 2 remain the same, 3 is changed into 5, 4 is changed into 3, and 5 is changed into 4. The standard convention is that Q.P means that P is applied first, then Q (but check with your teacher or text- that varies). So P leaves 1 along and then Q changes 1 to 2: together, 1 changes to 2. P leaves 2 alone and then Q changes 2 to 3: together, 2 changes to 3. P changes 3 to 5 and then Q leaves 5 alone: together, 3 changes to 5. P changes 4 to 3 and then Q changes 3 to 4: together 4 remains the same. P changes 5 to 4 and then Q changes 4 to 1: together 5 changes to 1. That is the permutation
[tex]\left(\begin{array}{ccccc}1 & 2 & 3 & 4 & 5 \\ 2 & 3 & 5 & 4 & 1\end{array}\right)[/tex]
In your notation I think that would be 2 3 5 4 1.
Similarly, P.Q means that we apply Q first. Q changes 1 to 2 and then P leaves 2 alone: together 1 changes to 2. Q changes 2 to 3 and then P changes 3 to 5: together 2 changes to 5. Q changes 3 to 4 and then P changes 4 to 3: together 3 stays the same. Q changes 4 to 1 and then P leaves one alone: together 4 changes to 1. Q leaves 5 alone and then P changes 5 to 4: together 5 changes to 4. That is
[tex]\left(\begin{array}{ccccc}1 & 2 & 3 & 4 & 5 \\2 & 5 & 3 & 1 & 4\end{array}\right)[/tex]
or, in your notation 2 5 3 1 4.
Again check your text's convention on order. If what your text has reverses those two answer, it is using the other convention.
To add, a permutation is a function, and the term "product" of permutations is actually a composition of functions, i.e. if P and Q are permutations of X, then the product PQ is defined as P(Q(x)), where x is an element of X.
thanks guys. i get it now :)
  • · Replies 31 ·
  • · Replies 21 ·
  • · Replies 0 ·
  • · Replies 0 ·
