Find the equivalent resistance of this 5-resistor circuit
The discussion revolves around finding the equivalent resistance of a circuit with five resistors. Participants explore various methods, including Kirchhoff's laws and delta-Y transformations, while addressing the complexities involved in the calculations.
  • Homework-related, Technical explanation, Exploratory, Debate/contested
  • One participant expresses confusion about how to start solving the problem and mentions using Kirchhoff's law without success.
  • Another participant suggests showing effort in schoolwork and hints at possible symmetries in the circuit that could simplify the problem.
  • A participant outlines equations derived from Kirchhoff's current law (KCL) but questions their relevance to finding the equivalent resistance.
  • Some participants discuss the delta-Y transformation as a method to simplify the circuit, with one noting that it is taught later in their course.
  • There is mention of the complexity of the equations involved and the challenge of having too many variables when attempting to find the equivalent resistance.
  • One participant claims to have understood how to find the equivalent resistance using the delta-star transformation and suggests that superposition on nodes could also clarify the solution.
  • Another participant encourages sharing the method used for superposition to help others in the future.
Participants do not reach a consensus on the best method to solve the problem, with multiple approaches discussed, including KCL and delta-Y transformations. The discussion remains unresolved regarding the most effective strategy for finding the equivalent resistance.
Some participants note the presence of many unknowns in their equations, which complicates the process of finding the equivalent resistance. There is also a mention of the need to derive transformation equations rather than using them directly.
aaronll
I have a question about an exercise I don't understand, I don't want the solution, only the first element to begin.
I have tried with kirchhoff law, but I failed.
thanks
Remember that you need to show some effort on schoolwork-type problems. If there are certain symmetries in this bridge circuit, you can sometimes simplify it. But in general you would use KCL or similar to solve it. Can you show us how to use KCL to solve it?
If I start with these equation, assuming current I_i for i = 1,2,3,4,5, and using KCL and what I know about circuit and correlated laws:
I have:
I_1 + I_2 = I_{tot}
I_1 = I_5 + I_3
I_2 + I_5 = I_4
I_3 + I_4 = I _{tot} and for general I have:
## R_{tot} = \frac{V_{AB}}{I_{tot}}##
with the equation:
R_1 * I_1 + R_3 * I_3 = V_{AB}
and so on, for total of 4 equation, each equal to V_{AB}
By now, is correct my resolution?
to me seem very strange
P.S. excuse for some LaTex code but seem not work, If you help me also with this :)
What you have written is correct (although I would give points off for your failure to SHOW the currents even though it's pretty clear that you are using a reasonable convention). BUT ... what does that have to do with the equivalent resistance? You are not asked to give a bunch of equations, you are asked to give ONE equation of the form
R_{eq} = <whatever>
R_{eq} = <whatever>
Yes, ##R_{tot}## that I have written is the ##R_{eq}##, but to find that resistance... I tried with KCL with that bunch of equation, but I don't arrive at the end because there always too much variable in the equation I found ( e.g. for replacement)
Do you know about delta-Y transforms?
According to my professor they come later.. so first I should able to resolve this exercise, but I don't understand how
Well, since you can't just USE the transform equations, it is now up to you to derive them. This will allow you to break your problem into two parts --- one fairly messy, the transform equations, and the other very simple conceptually but still involving messy equations in this case because you have so many unknowns.
Take the upper 3 resistors as a delta and convert that to a Y. That's the hard part. Then you have a very simple series/parallel circuit that is algebraically trivial but which will look messy as all get-out in this case because of the 5 unknowns you have to carry around.
The progression will look like this:
Literally speaking, the delta and Y are upside down in this case, but they are still delta and Y in electronics.
I should add, by the way, that there is usually more than one way to solve simple circuits like this and I've just given you my way because I think it's the easiest but that's 'cause I'm used to delta-Y transforms.
Finally I understand how to find the equivalent resistance with the delta - star transformation... but it was sufficent to say "Superposition on nodes" , because with that is totally clear.
Anyway thanks for the help.
I think the question was asking you, prompting you, to define, that is to write out the equation for equivalent resistance. Just for the sake of a logical and suggestive order of procedure.
Then this definition contained so it's related to things you have already written and you can start to fill in, substitute et cetera. As I said, just one way of proceeding there are more
Can you show us how you did it with "Superposition on nodes" so that when other people search for a solution to this problem in the future they will find your work?
  • · Replies 17 ·
13K
