Find the instantanous velocity
  • Thread starter Thread starter [Nicolette]
    Velocity
3 replies · 2K views
[Nicolette]
1. Homework Statement
Find the instantaneous velocity at t=1 by computing v(1)= [h(1+LaTeX Code: \\Delta t)-h(1)]/LaTeX Code: \\Delta t
I found that v(1)= -8ft/sec. Also I know h(1)=24 but i don't understand how to manipulate the h(1+LaTeX Code: \\Delta t) to get the solution.
2. Homework Equations
h(t)=16+24t-16t2
3. The Attempt at a Solution
The solution the teacher gave is v(1)=-8-16tLaTeX Code: \\Delta
Write out [tex]\frac{h(1+\Delta t)-h(1)}{\Delta t}[/tex]. The part you have a problem with is probably the [itex]h(1+\Delta t)[/itex] term I will give you a hint. [itex]h(1+\Delta t)=16+24(1+\Delta t)+...[/itex] fill in the rest and work out the brackets.
Note that for an instant of time [itex]\Delta t \rightarrow 0[/itex] so your final answer is correct.
How did you get that h(1+t)=16+24(1+t)?
and when i fill in the rest i get 16+24(1+t)-24 which when worked out would be 16+24t and is not right
:confused:
Don't overlook the dots. [itex]h(1+\Delta t)=16+24(1+\Delta t)+...[/itex] my intention was for you to fill in the dots, so basically add the quadratic term to it as well. I hope this is sufficiently clear if not just ask again!
Edit: I just noticed that the same question was asked in the correct introductory physics section. Perhaps a mod could merge this thread with https://www.physicsforums.com/showthread.php?t=305889.
