Find the Lead Pursuit Line to Reach a Planet
  • Thread starter Thread starter GrantB
    Lead Line
To reach a planet moving in a circular orbit while traveling in a straight line, one must determine the lead pursuit line based on the planet's constant angular velocity and their own constant speed. The discussion highlights the confusion around the initial conditions of movement, clarifying that the focus is on intercepting the planet rather than moving away from it. Insights from basic fighter maneuvers and missile guidance trajectories can be applied to solve this problem. The use of mathematical models and engagement geometry is suggested to derive effective guidance laws for interception. Understanding these principles is essential for calculating the correct trajectory to reach the moving planet.
GrantB
Suppose you are at a point (x0,y0) in space. There is a planet at position (x1,y1) orbiting in a circle a distance r away from the orbit center (x2,y2).
The planet has constant angular velocity as it orbits. You move at a constant speed towards the planet, and want to move in a straight line.
How do you determine how to reach the planet, traveling only in a straight line?
Thanks.
Astronomy news on Phys.org
GrantB, when you say "You move at a constant velocity from the planet,..." does that mean you are moving AWAY from the planet? Then you want to determine how to reach the planet, so I am confused.
So, I am guessing you may get some insight on the problem by considering this:
"Basic fighter maneuvers (BFM) are tactical movements performed by fighter aircraft during air combat maneuvering (also called ACM, or dogfighting), in order to gain a positional advantage over the opponent."
http://en.wikipedia.org/wiki/Basic_fighter_maneuvers
This article includes the Lead Persuit attack course, which you mention in the thread title, but do not mention in the post itself.
Sorry, it was a mistype.
It should say:
So, you want to get to the planet, and you are at an arbitrary point a distance d from the planet, moving only in a straight line.
Thanks, and sorry for the mistype.
I think your problem of intercepting a moving planet can be solved by using the methods of missile guidance trajectories. Here is an article you may be able to use. See:
www.jhuapl.edu/techdigest/TD/td2901/Palumbo_Homing.pdf
“Figure 2. Planar engagement geometry. The planar intercept problem is illustrated along with most of the angular and Cartesian quantities necessary to derive modern guidance laws.”
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Today at about 4:30 am I saw the conjunction of Venus and Jupiter, where they were about the width of the full moon, or one half degree apart. Did anyone else see it? Edit: The moon is 2,200 miles in diameter and at a distance of 240,000 miles. Thereby it subtends an angle in radians of 2,200/240,000=.01 (approximately). With pi radians being 180 degrees, one radian is 57.3 degrees, so that .01 radians is about .50 degrees (angle subtended by the moon). (.57 to be more exact, but with...
