Chemistry Find the molecules by interpreting the H NMR spectroscopy
The discussion focuses on interpreting H NMR spectroscopy to identify three compounds with the formula C6H12O2. Users analyze the integration ratios from the spectra, noting degrees of unsaturation for each graph. The first spectrum shows a 2:3:2:2:3 ratio, the second a 1:3:2:3:3 ratio, and the third a simpler 1:3 ratio. The challenge lies in determining the connectivity of the protons based on these integrations. Ultimately, the user successfully deduces the structures after careful consideration of the NMR data.
STLCards002
I have a 3 compounds with the same formula: C6H12O2
I need to find the molecules by interpreting the H NMR spectroscopy
http://aceorganic.pearsoncmg.com/epoch-plugin/tempfiles/1867_430.jpg
http://aceorganic.pearsoncmg.com/epoch-plugin/tempfiles/1869_524.jpg
http://aceorganic.pearsoncmg.com/epoch-plugin/tempfiles/1871_526.jpg
[/B]
I've tried so many structures that it would be pointless to name them off.
Don't start with structures - start with the spectrum. What does integration tell you about number of hydrogens? What does formula tell about saturation?
Well I know (atleast I think) the integrations;
1st graph: 2:3:2:2:3; One degree of unsaturation
2nd graph: 1:3:2:3:3; One degree of unsaturation
3rd graph: 1:3; One degree of unsaturation
But then I can't put everything together. I spend atleast an hour one each of these but can't figure out there connectivity.
3rd seems to be the simplest. 1:3 - you have two types of protons. How many of each type?
Each spike counts as 3 Hydrogens...so a CH3 and then 4 CH3?
I figured them out. Thanks for the help.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
