Find the period of oscillation of a little charged ring
The period of oscillation, T, of a charged ring positioned equidistant between two like charges can be determined using the formula T = 2π√(m/k). The net force acting on the ring can be simplified using the binomial expansion for small displacements, allowing the application of Hooke's law. The electric field at the ring's position is calculated using E = k*dq/r², where dq represents the charge and r the distance from the charges. This approach effectively models the system as a harmonic oscillator.
  • Understanding of electric fields and forces, specifically E = k*dq/r²
  • Familiarity with Hooke's law and its application in oscillatory motion
  • Knowledge of the binomial expansion for approximating functions
  • Basic principles of mechanics, particularly F = ma
  • Study the derivation of the harmonic oscillator model in physics
  • Explore the application of the binomial expansion in physics problems
  • Learn about the properties of electric fields generated by point charges
  • Investigate the effects of small displacements in oscillatory systems
Physics students, educators, and anyone interested in understanding the dynamics of charged particles in electric fields and harmonic motion.
anynamewilldo
Find the period of oscillation, T, of a little charged ring that is free to move along a vertical wire when placed equi-distant between two like charges above and below it. Small displacement only. Treat the “little” ring like a point charge and use the binomial expansion for small “x” to reduce the net force on the ring to a linear Hooke’s law style force.
T= 2pi*sqrt(m/k)
E = k*dq/r^2
F = ma
Since there are two charges and a point essentially you can calculate the electric field at a point p on the wire. Afterwards you can use F = ma at the field since F = qE = ma.
Am, I wrong about my thinking here. I really just want some help setting this up as in how I should start.
Also assume the "wire" is an electrically neutral insulator, but it sounds reasonable so far.
Keep going.
  • · Replies 68 ·
9K
