Finding the Collision Point of Two Objects Using Velocity and Position
To find the collision point of two objects with known velocities and positions, the relationship between distance and velocity can be utilized, where the time until collision is equal for both objects. The distance formula can be applied, but it is crucial to maintain consistent notation for position and velocity. By expressing positions as coordinate pairs and velocities as vectors, two linear equations can be formulated based on the equality of x and y coordinates at the time of collision. Solving these equations will yield the time of collision, allowing for the prediction of the collision point. This method effectively combines mathematical principles with clear notation for accurate results.
HuePig
I have 2 objects:
Obj1 have a Velocity of vel1 and position of (x1, y1)
Obj2 have a Velocity of vel2 and position of (x2, y2)
Using time = distance / velocity knowing that they will collide.. can I assume distance1 / vel1 = distance2 / vel2 ?
distance formula = sqrt((x - x1^2) + (y - y1^2))
Can I find the collision point(x, y) from the given and how?
Yes, ##\frac{{distance}_1}{{vel}_1}## will be equal to ##\frac{{distance}_2}{{vel}_2}## because both will be equal to elapsed time until the collision. But that does not help you much. Mathematically, the solution set of collision positions that fit that equation will be a line between the starting point of object1 and the starting point of object 2 so that the ratio of the distance to each starting point is the same as the ratio of the velocities.
Edit: There is the minor problem that you are dividing a scalar by a vector yielding a scalar. But one assumes that you are dividing by speed rather than velocity. So that concern goes away.
There are a number of ways to solve this problem. The first step is a better set of variable names. You have position as (x_1,y_1) and (x_2,y_2). But you have velocity as vel_1 and vel_2. That's inconsistent -- expressing position in terms of coordinate pairs and velocity in terms of vectors. Pick one notation and stick to it.
[Sometimes simply coming up with a notation that works so that you can write down the relevant equations is 90% of the problem]
For instance, how about position as (x1, y1) and (x2, y2) and velocity as (vx1,vy1) and (vx2, vy2).
Then you can write a formulas for the x coordinate of object 1 as a function of time (t), the y coordinate of object 1 as a function of time, the x coordinate of object 2 as a function of time and the y coordinate of object 2 as a function of time. You know that at the time of the collision, the x coordinates will be equal and the y coordinates will be equal. That leads to two equations. Write them down.
Two linear equations in one unknown... You should be able to solve at least one of them for the time (t) at which the collision occurs. Given starting position, velocity and time until the collision, it should them be possible to predict the position of the collision easily.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
