MHB Find the Set of Values for 'x' and 'z'
  • Thread starter Thread starter Petrus
    Set
The discussion focuses on solving a mathematical problem involving inequalities and complex numbers. The user initially determines the ranges for 'x' based on three parts of the problem, concluding that the intersection of these ranges is 4 < x ≤ 5. However, further clarification reveals that the correct intervals include 4 < x ≤ 5 and 2 ≤ x < 3. The conversation then shifts to solving a complex equation, where the user learns to complete the square to find a circular set of solutions rather than a single point. Overall, the thread emphasizes the importance of correctly interpreting inequalities and solving equations involving multiple variables.
Petrus
Hello MHB,
I am solving some old exam and I am stuck at one problem
it says 'outline the following two amounts'
If we start with number 1.
we know for the part $$(x-1)(x-5)\leq0$$ x has to be $$1\leq x \leq 5$$
part number 2.
$$(x-3)(x-4)>0$$ we know that $$x>4$$
part number 3.
$$(x-2)(x-6)\leq0$$ we have$$2\leq x\leq6$$
for number 1 and 2 we got
$$4 < x \leq 5$$
and part 2 and 3 we got:
$$4<x \leq 6$$
Is this correct?
Regards,
$$|\rangle$$
Re: Union
Petrus said:
Hello MHB,
https://www.physicsforums.com/attachments/767
part number 2.
part number 3.
$$4 < x \leq 5$$
$$4<x \leq 6$$
Is this correct?
Regards,
$$|\rangle$$
What you have said so far is correct but you have not finished the problem. The intersection is the set of all numbers that are in all of those intervals. You have that some of the numbers are in 4< x< 5 and some are in 4< x< 6. Numbers that are in both are all the numbers in 4< x< 5.
Re: Union
Hello HallsofIvy,
so for all those three range the answer to the question is $$4< x \leq 5$$?
Regards,
$$|\rangle$$
Re: Union
Petrus said:
Hello HallsofIvy,
Regards,
$$|\rangle$$
According to your answer the only integer solution is 5 , check if that is true .
Re: Union
Hello ZaidAlyafey,
the facit says $$[2,3)$$U$$(4,5]$$ and I don-t understand how :S
Regards,
$$|\rangle$$
Re: Union
Petrus said:
part number 2.
Recheck this one .
Re: Union
ZaidAlyafey said:
Recheck this one .
Hello ZaidAlyafey,
Darn it... I see... I did NOT think clear...we got $$x>4$$ or $$x<3$$
so we got $$4<x \leq 5$$ or $$2 \leq x <3$$ Thanks alot!:) I will keep try b and will be back if I am still stuck!
Regards,
$$|\rangle$$
Hello,
I am back for the b) This is my progress:
we got $$Re[(z-1)(\overline{z}+i)]=\frac{1}{2}$$ so we start with
$$(z-1)(\overline{z}+i) = z\overline{z}+zi-\overline{z}-i$$
$$z=x+yi$$
$$\overline{z}=x-yi$$
we get that:
$$x^2+y^2+xi-y-x+yi-i$$
with other words we got this equation
$$x^2+y^2-y-x=\frac{1}{2}$$ (Re)
$$x+y-1=0 <=> x+y=1$$ (Im)
Now I am stuck on how to solve them
Regards,
$$|\rangle$$
Hi Petrus, at the bottom, in your x + y = 1 , that 1 should be i
Hello agentmulder,
I did factour out i, that is why I got 1, I should write $$i(x+y-1)=0i$$
Regards
$$|\rangle$$
You cannot conclude that $$\text{Im}[(z-1)(\overline{z}+i)] =0 $$
Ok I thought I could, but how shall I solve that Re equation?
Regard
$$|\rangle$$
Petrus said:
Hello agentmulder,
Regards
$$|\rangle$$
Oh shoot, missed that, you're right of course.
First note that the solution will not be a finite number of points since we have an equation with two variables
We complete the square
$$x^2-x+\frac{1}{4}- \frac{1}{4} +y^2- y+ \frac{1}{4}-\frac{1}{4} = \frac{1}{2}$$
$$\left( x-\frac{1}{2} \right)^2+ \left(y-\frac{1}{2} \right)^2=1$$
so what do you conclude ?
Hello Zaid,
I get problem when solving that equation, if $$x,y=\frac{1}{2}$$ it will be zero? Well facit says it should be $$x,y=\frac{1}{2}$$ but I don't understand
Regards,
$$|\rangle$$
Petrus said:
Hello Zaid,
Regards,
$$|\rangle$$
I cannot see why it should be just one point , the set of solutions will lie on the circle with center $$\left( {1 \over 2} , {1\over 2} \right) \,\, $$ and radius $$ r=1$$
Hello Zaid,
I see they did prob mean that :P May I ask you how did you think when you did that factour part, how did you know you would add and take away $$\frac{1}{4}$$? I need to practice those thing, any tips?
Regards,
$$|\rangle$$
Petrus said:
Hello Zaid,
Regards,
$$|\rangle$$
Suppose we have the following $$x^2+bx+c$$ and you want to complete the square ,
Find the coefficient of x , which is b .
Divide it by 2 and square the result , $$\frac{b^2}{4}$$.
Add and subtract to have a complete square .
$$x^2+bx+\frac{b^2}{4} -\frac{b^2}{4} + c = \left( x+ \frac{b}{2} \right)^2 + c -\frac{b^2}{4} $$
Thanks evryone for all help and taking your time! Now I do understand but practice need :)
Regards,
$$|\rangle$$
You might find this http://www.mathhelpboards.com/f21/teach-complete-square-3817/beneficial .
