Find the speed of an electron given momentum
To find the speed of an electron given its momentum of 2.74 x 10^-22 kg·m/s, the correct approach involves using the equation p = γmv, where γ (gamma) accounts for relativistic effects. The initial attempt to calculate speed using v = p/m is incorrect because it does not consider the relativistic factor. Instead, the speed should be calculated using v = p/(γm), requiring the expression for γ to be defined in terms of v. This leads to a more complex equation that must be solved iteratively or through substitution. Understanding the relationship between momentum, mass, and relativistic speed is crucial for accurate calculations.
psilovethomas
An electron has momentum of magnitude 2.74 10-22 kg · m/s. What is the electron's speed?
p=ymv, where y=gamma
v=p/m, which is wrong. Any suggestions?
If p = γmv, then v = p/γm not p/m. Of course, γ itself is a function of v, so you need to write it out and then solve for v correctly.
