Find the tension in the wire and the components of the force exerted
The problem involves a bear walking on a beam to retrieve a basket of food, requiring the calculation of tension in a wire and the components of the force exerted by the wall on the beam. The scenario includes a uniform beam, the weight of the bear, the basket, and the beam itself, with specific positions and angles mentioned.
  • Mixed
  • Participants discuss the setup of the problem, including the balance of forces and torques. There are attempts to derive equations for the y-component of the force at the wall and the tension in the wire. Some participants question the assumptions about the beam's support and the angles involved.
The discussion is ongoing, with various participants providing insights and corrections regarding the calculations. Some guidance has been offered regarding the interpretation of the forces involved, but no consensus has been reached on the final values or methods.
There are mentions of specific numerical values and potential confusion regarding the weights involved, as well as the implications of the angle in the calculations. Participants express concern about accuracy due to limited attempts remaining for homework submission.
yb1013
A hungry bear weighing 720 N walks out on a beam in an attempt to retrieve a basket of food hanging at the end of the beam. The beam is uniform, weighs 200 N, and is 5.40 m long; the basket weighs 80.0 N.
a) When the bear is at x = 1.00 m, find the tension in the wire and the components of the force exerted by the wall on the left end of the beam.
N (tension)
N ( Fx)
N ( Fy)
Okay well I sort of understood this question and created a balanced torque equation. After doing this I got that:
Tension = 345.66
Fx = 172.83
But I need help with finiding Fy Please.
I only have like one more chance to answer the question on my homework so I want to make sure I can get the right answer.
I know I have to write out some equation like maybe:
Rsin(theta) = 720 + 200 + 80 - 345.66sin(60)
Is this correct? And if its not, am I on the right track?
is the beam supported by a horizontal string on each end?
Need more data on how the beam is supported.
Sounds like a cantilever beam with a tension wire at the other end, but is this tension wire vertical or anchored to the wall.
Tension = 345.66
Fx = 172.83
But when I go for Fy using 345sin(60), I keep getting 299 which my homework keeps telling me is wrong..
Hi yb1013! :smile:
I think you've calculated the y-component of the tension, instead of the y-component of the force at the wall. :redface:
would this be closer to the y-component for the force?
what a dumb bear...
Anyways, I broke the componets into x and y directions. The y dir. is Tcos(theta) -mg =0 due to their being no motion.
also, their are 3 masses. bear, basket, and beam.
xxChrisxx said:
Its yogi bear...!
Thats some nice pic-a-nic
He's smarter than the average bear! :biggrin:
Yup … if the tension is right, then that looks right too! :smile:
Ashleyz said:
what a dumb bear...
So would it go like 345.66cos(60) - 1020 = 0 ??
Ok well the numbers in that question aren't actually my exact numbers, but with my numbers I come out with:
Rsin(theta) = 720.65
would that mean that its:
Rsin(60) = 720.65
R = 832.13
So 832.13 would be the force in the y-component??
I only have one more guess left on my homework, so I want to make sure lol
uhh? :confused:
perhaps I misunderstood your Rsin(theta) …
I assumed you meant that to be the y-component of the reaction force at the wall:
Ry = 720 + 200 + 80 - 345.66sin(60)
(ooh, and it's 1000 not 1020 :wink:)
tiny-tim said:
uhh? :confused:
Yea forget what I just said, I had a brain fart for a second there lol
Its just 720, sorry about the confusion.
Thanks again!
yb1013 said:
… Its just 720 …
better check that …
well its right, I stated in one of my other posts that the numbers were exactly what my actual problem contained. the 720 N of the bear is actually 740, which is why when I added all the numbers up I got 1020 instead of 1000.. So in the end the force is equal to 720
Sorry for all the confusion
stuffing down more goodies than the average bear …
ah :rolleyes:heavier than the average bear! :biggrin:
