MHB Unique Solution for 3 Simultaneous Equations with Integers: x, y, z
  • Thread starter Thread starter anemone
The discussion focuses on solving three simultaneous equations involving integers x, y, and z. Participants confirm that there is indeed a unique solution, which is x = -3, y = 2, and z = -4. The method involves analyzing cases based on the signs of x, y, and z, leading to the conclusion that the case where x is positive yields no valid solutions. The conversation highlights the elegance of the solution method and the importance of adhering to the conditions set by the equations. The unique solution is established through careful consideration of the equations' constraints.
anemone
MHB
POTW Director
Consider the 3 simultaneous equations
$$|x|-y-z=5$$
$$x-|y|+z=-9$$
$$x-y+|z|=-1$$
Find the unique solution of the simultaneous equation in which $x, y, z$ are all integers.
Mathematics news on Phys.org
My solution
Maybe not the most elegant but effective. Due to the presense of the absolutes we can consider 8 cases depending on whether $x, y$ and $z \ge 0$ or $< 0$. However we can rule out 6 of these immediately due to inconsistencies in the system. For example, if $x,y,z \ge 0$ the the system is
\begin{eqnarray}
x - y - 5 &=& 5\\
x-y+z &=& -9\\
x - y + z &=& -1
\end{eqnarray}
and clearly the last 2 equations are inconsistent. The only cases I found that were consistent where
\begin{eqnarray}
(i) & \;\;&x \ge 0,\;\;& y < 0,\;\; &z \ge 0\\
(ii)& \;\;&x <0.\;\; &y \ge 0,\;\;& z < 0
\end{eqnarray}
In each case, the systems were easily solved giving solutions $(-2.-4,-3)$ and $(-3,2,-4)$.
Jester said:
My solution
But you have 2 solutions, when surely there should only be one?! (Nerd)
Can you scratch the first one please?
(I selected the same method.)
Jester said:
My solution
\begin{eqnarray}
x - y - z &=& 5\\
x-y+z &=& -9\\
x - y + z &=& -1
\end{eqnarray}
\begin{eqnarray}
\end{eqnarray}
As I like Serena pointed out, there is a unique solution. Clearly my first solution violates the condition $x \ge 0$ and $z \ge 0$.
Hi Jester,
Thanks for participating and I think your method is quite elegant and I used the same concept to solve it too.
Hi I like Serena,
Thanks for everything!
But I have thought of another method to tackle the problem and the idea only hit me moment ago.
We're given to solve for the unique solution of the simultaneous equation below in which $x, y, z$ are all integers.
$$|x|-y-z=5$$---(1)
$$x-|y|+z=-9$$---(2)
$$x-y+|z|=-1$$---(3)
[TABLE="class: grid, width: 500"]
[TR]
[TD]Adding the equations (1) and (2) gives[/TD]
[TD]Adding the equations (1) and (3) gives
[/TD]
[TD]Adding the equations (2) and (3) gives
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]$$|x|+x=|y|+y-4$$[/TD]
[TD]$$|x|-x=|z|+z+6$$[/TD]
[TD]$$|y|-y=z-|z|+8$$[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Let $x<0$.
We then have
$$0=|y|+y-4$$
This implies $y=2$.[/TD]
[TD][/TD]
[TD]When $y=2$, we have
$$0=z-|z|+8$$
This gives $z=-4$.[/TD]
[TD]When $x<0$, $y=2$, $z=-4$,
$$|x|-x=|z|+z+6$$ becomes
$$-2x=6$$
$x=-3$[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Now, we have to consider the case when $x>0$.
When $x>0$, we have
$$0=|z|+z+6$$
And obviously the equation above has no solution and we're done! Yeah!(Sun)
[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
