Find the values of a, b, c and k.
  • Context: MHB
  • Thread starter Thread starter anemone
The discussion revolves around finding the values of the roots \(a\), \(b\), \(c\) and the parameter \(k\) for the polynomial equation \(x^3-6x^2+kx+k=0\) under the condition that \((a-1)^3+(b-2)^3+(c-3)^3=0\). The scope includes mathematical reasoning and exploration of different cases based on the roots of the polynomial.
  • Some participants note that since \(a+b+c=6\), it follows that \((a-1)+(b-2)+(c-3)=0\), leading to the conclusion that \((a-1)^3+(b-2)^3+(c-3)^3=3(a-1)(b-2)(c-3)\).
  • Others argue that this implies \((a-1)(b-2)(c-3)=0\), suggesting at least one of \(a=1\), \(b=2\), or \(c=3\) must hold.
  • A participant presents a case analysis starting with \(a=1\) and derives equations for \(b\) and \(c\) using Newton's identities, leading to specific values for \(k\) and the roots.
  • Another participant follows a similar approach, confirming the relationships between the roots and deriving values for \(k\) based on the assumption of different roots being equal to 1, 2, or 3.
  • Some participants express astonishment at the relationships discovered among the roots, while others emphasize the need to investigate each case thoroughly.
  • There are multiple sets of roots proposed, indicating that different assumptions lead to various solutions for \(k\) and the roots \(a\), \(b\), and \(c\).
Participants generally agree on the relationships between the roots and the polynomial coefficients, but multiple competing views remain regarding the specific values of \(a\), \(b\), \(c\), and \(k\). The discussion is unresolved as different cases yield different sets of solutions.
Limitations include the dependence on the assumptions made about the values of \(a\), \(b\), and \(c\), as well as the unresolved nature of the mathematical steps leading to the various proposed solutions.
anemone
MHB
POTW Director
Hi,
The problem stated below has me stumped. I've been trying to solve it for some times but I kept ended up with zero equals zero kind of silly result and I'd appreciate it if someone could show me some ideas on how to crack it.
Thanks in advance.
Problem:
Let $$a,\;b,\;c$$ be roots of equation $$x^3-6x^2+kx+k=0$$ and $$(a-1)^3+(b-2)^3+(c-3)^3=0$$. Find a, b, c and k.
Mathematics news on Phys.org
anemone said:
Hi,
Thanks in advance.
Problem:
Since $a,b,c$ are roots of $x^3-6x^2+kx+k=0$, we have $a+b+c=6\Rightarrow (a-1)+(b-2)+(c-3)=0$. This means $(a-1)^3+(b-2)^3+(c-3)^3=3(a-1)(b-2)(c-3)$. So you get $(a-1)(b-2)(c-3)=0$.
Now
We already have $ab+bc+ca=k$ and $abc=-k$. This should help.
Thanks caffeinemachine for the quick reply..
I'm astonished to see another relation exists between $a,b,c$, i.e $(a-1)+(b-2)+(c-3)=0$. I must thank you for that!:)
If I may start from $(a-1)+(b-2)+(c-3)=0$, I get:
$(a-1)+(b-2)=-(c-3)$
$((a-1)+(b-2))^3=(-(c-3))^3$
$(a-1)^3+3(a-1)^2(b-2)+3(a-1)(b-2)^2+(b-2)^3=-(c-3)^3$
$(a-1)^3++(b-2)^3+(c-3)^3+3(a-1)(b-2)((a-1)+(b-2))=0$
$(a-1)^3++(b-2)^3+(c-3)^3+3(a-1)(b-2)(a+b-3)=0$
$(a-1)^3++(b-2)^3+(c-3)^3+3(a-1)(b-2)(6-c-3)=0$
$(a-1)^3++(b-2)^3+(c-3)^3+3(a-1)(b-2)(3-c)=0$
Since we're told that $(a-1)^3++(b-2)^3+(c-3)^3=0$, it means $3(a-1)(b-2)(3-c)=0$, or
$a=1,\;b=2,\;c=3$.
Since $ab+bc+ac=k$ and $abc=-k$, we noticed that $a=1,\;b=2,\;c=3$ can't be true at the same time. In other words, we need to investigate for each of the cases.
Case 1 (When $$a=1$$):
From the Newton Identities we obtained the following equations:
$$a+b+c=6$$
$$a^2+b^2+c^2=36-2k$$
$$a^3+b^3+c^3=216-21k$$
Substitute $$a=1$$ into each of the equations above leads us to
$$b+c=5$$
$$b^2+c^2=35-2k$$
$$b^3+c^3=215-21k$$
And by using the identity $$b^3+c^3=(b+c)(b^2-bc+b^2)$$ and $$(1)(bc)=-k$$, we get:
$$k=\frac{5}{2},\;b=\frac{5-\sqrt{35}}{2},\;c=\frac{5+\sqrt{35}}{2}$$
And we repeat all these for the second and third cases to find
$$a=\frac{2(3+\sqrt{5})}{2},\;b=2,\;c=\frac{2(3-\sqrt{5})}{2},\;k=\frac{16}{3}$$
and
$$a=\frac{3(1+\sqrt{2})}{2}\;c=\frac{3(1-\sqrt{2})}{2},\;c=3,\;k=\frac{27}{4}$$
Yeah! It seems to me now that this is an easy problem!:o
Thank you enormously, caffeinemachine!:)
Umm.. err.. uh.. You're.. err.. welcome. (Wasntme)
I proceed slight differently
We have sum of the roots
a+b+c = 6
so (a + b+ c- 6) = 0
or (a-1)+(b-2)+(c-3) = 0
so (a-1)^3 + (b-2)^3 + (c-3)^3= 3(a-1)(b-2)(c-3) ( as x+ y + z = 0 => x^3+y^3 + z^3 = 3xyz
so 3(a-1)(b-2)(c-3) = 0 => a= 1 or b= 2 or c = 3
f(x) = x^3−6x^2+kx+k
taking 1 as a root we get
f(x)= 1-6+ k+ k = 0 or k = 5/2
so we get x^3-6x^2 + 5/2 x + 5/2 = 0
or 2x^3 – 12x^2 + 5 x + 5 = 0
factoring we get (x-1)(2x^2 – 10 x - 5) = 0
we can solve (2x^2 – 10 x - 5)= 0 to get (10+/-√(140))/4 so b = (5+ √35)/2 and c = (5 - √35)/2
another solution b = 5- √35)/2 and c = (5 - √35)/2
similarly other 4 sets of 3 roots can be found
b = 2 shall give 2 sets and c = 3 shall give 2 sets
( kindly note that as we have been given the condition
(b = x1, c= x2) is different from ( b = x2, c= x1))
