Find the velocity of a block + 2 cylinders acted on by a force for 2meteres
A 50 kg block is moved by a force of 125 N using two 17.5 kg cylindrical rollers over a distance of 2 meters. The problem involves calculating the block's speed after displacement, considering no slipping occurs. The equations of motion and energy conservation are applied, with the moment of inertia for the cylinders factored in. The attempt at a solution suggests that the acceleration of the block is influenced by the tension in the rollers. The expected final speed of the block is calculated to be 2.8 m/s, indicating a potential error in the energy calculation.
deanr
A 50 kg block is transported a short distance by using two cylindrical rollers, each having a mass of 17.5 kg. If a horizontal force P=125N is applied to the block, determine the block's speed after it has been displaced 2m to the left. Originally the block is at rest. No slipping occurs.
The radius of the cylinders: .5m
T1+U1->2=T2
U=F*d+M*\theta ?
\omega = 2 \times v
Icyl=2.1875 kgm^2
T1=0
U1->2=125 \times2+(125 \times .5) \times 2
T2(block)=\frac {1}{2} \times m \times v^{2}
T2(rollers)=2 \times ( \frac{1}{2} \times m \times v ^{2})+2 \times ( \frac{1}{2} \times Icyl \times (2v)^{2})
the answer should be v=2.8 m/s but I think I am working out U1->2 incorrectly
Well, you know that the force that is acting on the rollers is equal to the force applied contrary to the P, as there's no slliping...
so, the aceleration of the block is a=(P-2T)/m where m is block mass, P the force, and T the force that provokes a torque on each roller..
