student85 said:
Easier said than done! My tool box doesn't come with an airplane tire gauge that goes up to several hundreds of psi.
Then take a pencial a draw the outline of the area of each tire in contact with the ground. make the plane move and calculate the area of each area you outline.
I don't imagine it's easy to "make the plane move", but that is not particularly important. A good estimate of the contact area can be made without moving the plane.
Then the force exerted by the plane on the ground would be the pressure of each tire multiplied by its corresponding area of contant to the ground. Sum all three forces.
There are six wheels, but that's just a detail.
Divide this by 9.81 and get the mass.
Sounds like a good plan! Only thing to figure out is how you'd measure the tire pressure. Remember, this is probably at least a couple hundred psi!
Now, if it were only possible to measure the contact area to an extremely high accuracy (better than 1ppm), you wouldn't need to know the tire pressure. Just measure the area twice, once with, and once without the toolbox on the plane.
If the tires had some kind of release valve, you could let the air out and measure its volume at STP (allow it to inflate a trash bag, or make it displace a liquid like airplane fuel). To improve the estime, I'd repeatedly measure the tire area as a function of volume of air released, plot it, fir it to an ideal gas curve and estimate the pressure. Alternatively, if the release valve has a cross section area smaller than a square inch, it may be easier to measure the force required to manually plug it.
