Finding a complex Taylor series
MorePowerrr
Not much has gotten me in this class, and I almost want to say this has to be a typo, but I want someone else to check it out first.
Homework question is that we need to show that
cos(cos θ)*cosh(sin θ) = Ʃ(-1)ncos(nθ)/(2n)! for n>=0
There is a similar one involving sin and sinh, but if the problem is sorted out here on this one, I can fix it for the other one.
Since cosh(x) = cos(i*x), I can rewrite my original function as
cos(cos θ)*cos(i*sin θ).
Using a product-to-sum trig identity, this eventually gets me to
1/2*[cos(exp(-iθ))+cos(exp(iθ))].
But because of the Taylor series for cosine, I end up with an exp(-2inθ) and exp(2inθ).
So I end up getting the series I expect, except I have a cos(2nθ) which does not match. Is there a division by 2 I'm missing somewhere or some quirky identity that makes it true that cos(2nθ)=cos(nθ)?
No quirky identity can make cos(2nθ)=cos(nθ), because it's not true. I think you are right and there is a typo in the solution.
That's what I thought. Thanks for clarifying. I'll point it out on Monday in class and hopefully I'm not the only one that noticed that.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
