Finding a particular level curve of a function z=f(x,y)
  • Thread starter Thread starter cdot
    Curve Function
cdot
For the function z=f(x,y)=4x^2-y^2+1 I need to set z to a constant c so that the level curve created by the intersection of f(x,y) with the plane z=c is two intersecting lines. I know that the cross section of the function with x fixed is a parabola opening down and the cross section of the function with y fixed is a parabola opening up (it's a hyperbolic paraboloid).
z=4x^-y^2+1
I've graphed the function on wolfram alpha and I'm trying to visualize slicing the surface with horizontal planes but I can't seem to visualize at what value of z you would get two intersecting lines as a level curve.
z=4x^2-y^2+1
If z = c, your equation becomes equivalent to:
\displaystyle <br /> 4x^2-y^2=c-1\,,​
which for most values of c is the equation of a pair of hyperbolas.
The left hand side is the difference of squares so the equation is equivalent to:
\displaystyle <br /> (2x-y)(2x+y)=c-1\ .​
What must the value of c be to make the solution to this be two lines?
If I set z equal to 1 the solution is y=2x and y=-2x. Thank you!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
