Find Actual Price of 8lbs Roast Beef - $22.32
  • Thread starter jacy
In summary, the actual price of 8lbs of roast beef for $22.32 can be found by dividing the total cost by the weight, resulting in a price of $2.79 per pound. Whether this is a good deal depends on the current market price for roast beef. The weight of roast beef directly affects its price, with larger quantities typically having a lower price per pound. When calculating the actual price of roast beef, it's important to consider additional costs such as taxes and shipping fees. While the actual price may vary slightly, it should provide a good estimate of the true cost of the meat.
jacy
76
An 8 lbs. roast beef cost $2.79/lb. The edible portion is 65%. What is the actual price of the roast.?
This is what i did
1lb cost $2.79, so 8lbs cost $22.32. Am i correct, this will be the actual price right. What do i need to do with 65%. Please help.
Of the 8 lbs of roast beef, only 65% or 0.65 is edible, the rest gets thrown away.
So how much roast beef is one actually buying?
Based on the given information, your calculation for the actual price of the 8lbs roast beef is correct. However, in order to determine the actual price, you also need to take into account the edible portion of the roast. This means that only 65% of the 8lbs will be used for consumption, while the remaining 35% will be inedible.
To calculate the actual price, you can multiply the cost per pound ($2.79) by the weight of the edible portion (8lbs x 65% = 5.2lbs). This would give you a price of $14.49 for the edible portion of the roast. Therefore, the actual price of the 8lbs roast beef would be $14.49.
In conclusion, the actual price of the 8lbs roast beef is $14.49, taking into consideration the cost per pound and the edible portion. This calculation is important for accurate cost analysis and budgeting in scientific research and food production.
1. How do I find the actual price of 8lbs of roast beef for $22.32?
The actual price of 8lbs of roast beef for $22.32 can be found by dividing the total cost by the weight. In this case, the price per pound would be $22.32/8lbs = $2.79 per pound.
2. Is the price of $22.32 for 8lbs of roast beef a good deal?
It depends on the average market price of roast beef. You can research the current market price for roast beef and compare it to the price of $22.32 for 8lbs to determine if it is a good deal.
3. How does the weight of roast beef affect its price?
The weight of roast beef directly affects its price. Generally, the more roast beef you purchase, the lower the price per pound will be. This is because the cost of production and packaging is spread out over a larger quantity of meat.
4. Are there any additional costs to consider when calculating the actual price of roast beef?
Yes, there may be additional costs such as taxes, shipping fees, and any applicable discounts or promotions. These should be factored in when calculating the actual price of roast beef.
5. How accurate is the actual price of roast beef?
The actual price of roast beef may vary slightly due to factors such as fluctuations in market prices or variations in weight. However, it should give you a good estimate of the true cost of the meat.
  • Mechanical Engineering
  • General Math
