Finding angle of inclination. Hanging object.
The discussion revolves around calculating the angles of inclination for two hanging objects, AB and BC, with lengths of 30 cm and 40 cm, respectively. Participants suggest using moments about point B to find the angles where the forces cancel each other out. The conversation highlights the importance of understanding the perpendicular distance from the pivot point to the line of force and the use of trigonometric functions to solve for angles. Clarifications on the formulas and concepts of moments and forces are provided, emphasizing the need to visualize the problem geometrically. Ultimately, the solution involves using ratios of the weights and lengths of the objects to derive the angles.
EVriderDK
I have to find the angles from horizontal of AB=30cm and BC=40cm.
http://peecee.dk/upload/view/356001
I don't know how to tackle this one.
I was told that i could see them as lever arms, and find out at which angle they cancel each other out. I'm not sure how to do that.
Thanks you in advance.
Welcome to PF!
Hi EVriderDK! Welcome to PF! :wink:
Draw the forces (the two weights), and take moments about B …
what do you get? :smile:
Thank you :)
I could do that, if it was a straight line, but how to do it when it is bend in 90 degrees?
Have you done moments of forces?
I have solved these ones fx:
http://peecee.dk/upload/view/355632
http://peecee.dk/upload/view/353915
Hope you don't mind the danish :)
But do you know how to calculate the moment of a general force about a general point? :confused:
Yes. It is just Force/length ?
Noooo :redface:
You need to look it up in your book.
(and I'm off to bed :zzz:)
Woops meant F*r :D
EVriderDK said:
Woops meant F*r :D
what is r ?
Radius or length
of what?
from what to what?
From the "rotation point" B to the end of an arm/lever.
ah, no :redface:
it's the perpendicular distance from B to the line of the force
(in this case, the force is the weight, so the line of the force is the vertical line through the centre of the rod)
another formula is F.d (or Fdsinθ)
where d is the vector from B to the centre of mass, and θ is the angle between F and d
see http://hyperphysics.phy-astr.gsu.edu/hbase/torq2.html :wink:
Hmm.
B is a point. How can something be perpendicular to a point?
Centre of the mass? So i have to make a triangle out of it, and find the center of gravity?
i don't understand
either follow the diagram, http://hyperphysics.phy-astr.gsu.edu/hbase/torq2.html, or follow my instructions
I'm looking at the site, but it doesn't make sense. Maybe I'm just not that good at english :) It's confusing.
I don't know what you mean by F.d. What does "." represent ?
If the Force is the force of gravity, and the force of gravity is a vertical force through the point B, how can i make a line perpendicular to the force(Fg) and B?
That's the dot product (or scalar product), see http://hyperphysics.phy-astr.gsu.edu/hbase/vsca.html
If you don't like the idea of dot product, just use the Fdsinθ formula :smile:
No, you make it through B (or from B), and perpendicular to that vertical line.
In other words: if d is the distance from B to the centre of the rod,
then dsinθ is the horizontal distance from B to the vertical line through the centre of the rod.​
So d is a line from the middle of AB, perpendicular to AB, which goes to F_g, which is the vertical force through B ?
Dot product and vector calculations is long gone. Cannot remember how it works, so another method is preferrable :)
No!
Read the instructions
it's perpendicular to the force
and it's through B (the pivot point)​
I found another solution, where the Fg goes vertically down in the middle of AB(a). From that point you draw a vertical line to the top, and a horizontal line to the pivot point B. The same with BC(c). To calculate the ange, i first have to find out, where the two moments are =0. So that will be F_g_a*Cb*sin(alpha)-F_g_b*Ca*cos(alpha)=0.
Right?
EVriderDK said:
I found another solution …
That is the solution I've been telling you about!
… where the Fg goes vertically down in the middle of AB(a). From that point you draw a vertical line to the top, and a horizontal line to the pivot point B. The same with BC(c). To calculate the ange, i first have to find out, where the two moments are =0. So that will be F_g_a*Cb*sin(alpha)-F_g_b*Ca*cos(alpha)=0.
Right?
You mean F_g_a*Ba*sin(alpha)-F_g_c*Bc*cos(alpha)=0 ?
Right! :smile:
(if alpha is what I think it is)
Now what is the ratio of F_g_a and F_g_c? :wink:
60.64deg/29.538=2.053
1:2.053 ?
1:2.053 ?
uhh? :confused:
F_g_a/F_g_c = weight of BA / weight of BC = length BA / length BC
3/4 ?
Yup! :biggrin:
(why the question-mark? :wink:)
Now put it all together! :smile:
I was not sure what you wanted :)
atan(20^2/15^2)
atan(30^2/40^2)
That is much easier. I just had no clue, why this is possible. I lack the understading of it :/
