person_random_normal
- 165
- 10
how do we find change in entropy for two points on a P V diagram which are not an isotherm
The temperature at the initial state may not be the same as the temperature in the final state. So the path may not be totally isothermal. But you have the right idea.MexChemE said:Since the change in entropy of the system only depends on the initial and final states of the system, you can design an isothermal reversible process which goes from the intial point to the final point indicated by the diagram and easily calculate its ΔS. It will be the same even if the actual process you are studying is not isothermal or reversible.
