Finding charge with mass, length and separation
Averiex
I don't even know where to start..
Two styrofoam balls with the same mass (m=9.0x10^-8 kg) and the same positive charge Q are suspended from the same point by insulating threads of length (L=0.98 m). The separation of the balls is (d=0.020 m). What is the charge Q??
Welcome to the forum.
First you should sketch the situation. Also include all forces acting on the balls.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
