Finding Eigenvalues and Bases of Eigenspace for a Given Matrix
  • Thread starter Thread starter ihumayun
    Basis
The problem involves finding the eigenvalues and bases of the eigenspace for a given matrix A. The matrix is presented, and it is noted that it has one real eigenvalue, prompting the search for this eigenvalue and a basis of the eigenspace.
  • Exploratory, Assumption checking
  • Participants discuss the calculation of the eigenvalue, with one confirming it as zero. There is confusion regarding the number of bases needed, as the original poster believes two bases are required despite others suggesting only one is necessary. Various attempts to express the relationships between variables are shared, with some participants asking for clarification on the steps taken to derive the basis.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the nature of the basis, and there is a recognition of the potential for multiple vectors in the eigenspace. However, there is no explicit consensus on the number of bases required.
There is a noted discrepancy between the original poster's understanding of the problem requirements and the interpretations of other participants. The original poster's professor has confirmed the need for two bases, which adds to the complexity of the discussion.
ihumayun
The matrix A=
2 0 4
-2 0 -4
-1 0 -2
has one real eigenvalue. Find this eigenvalue and a basis of the eigenspace.
Eigenvalue =
Basis ( , , )T , ( , , )T
I have found the eigenvalue to be 0, but I can't seem to figure out how to come up with 2 bases. I found the first one:
2x + 4z = 0
-2x - 4z = 0
-1x - 1z = 0
All three equations reduce to :
x + 2z = 0
So then,
x = t , y = 0, and z = -(1/2)t
which gives a basis of (1, 0, -1/2)T
I'm not completely sure that I have calculated this correctly, and I have no idea how to come up with the second basis. The eigenvalue I calculated was marked correct, though. If anyone could help me, I would greatly appreciate it. :)
You only have one eigenvalue so you will have only one basis.
Your question states "Find this eigenvalue and a basis of the eigenspace".
Correct me if I am wrong but you should only need to find one basis.
Thanks
Matt
x + 2z = 0
So then,
Could you show your work here?
I also thought that there should be only one basis, but the question asks for 2, and my prof confirmed this. I still don't understand how this would work though.
My work:
x+2z=0
2z = -x
z = - x/2
So if I set x with the parameter t,
x=t
y=0
and z = -t/2, or (-1/2) t
Sorry I didn't include this before .
ihumayun said:
z = - x/2
x=t
y=0
and z = -t/2
y doesn't appear in that equation -- how did you conclude something about it?
Because the equation was
x +2z = 0 or
1x + 0y +2z = 0
y is nonexistent in this case. I assumed that would mean it would be equal to 0 in the basis, but like I said, I wasn't sure if I had calculated the basis correctly. How would I find a value for y?
All equations reduce to x+ 2z= 0 so x= -2z. z can be anything at all and y can be anything at all. Your basis contains two vectors.
So how would I find the bases in that case?
Oh, I just got it.
x = -2t
y = s, not 0
and z = t
which means that the vector would be:
(-2t , s, t)T = (-2t, 0, t)T + ( 0, s, 0)T
which gives the bases
(-2, 0, 1)T, and (0, 1, 0)T
Thank you for your help!
  • · Replies 24 ·
  • · Replies 19 ·
