Finding Electron Speed and Wavelength
To find the speed of an electron given its wavelength of 4.4 × 10−7 m, the de Broglie relation λ = h/p can be used, where h is Planck's constant (6.62607 × 10−34 J·s) and p is momentum. The mass of the electron can be looked up to calculate its speed by rearranging the equation. For the second part, with the electron speed of 9 × 10^6 m/s, the wavelength can again be determined using the de Broglie relation, rearranging it to solve for λ. This approach effectively links the electron's speed and wavelength through fundamental physics equations.
purecp
The wavelength of an electron is 4.4 × 10−7 m.
How fast is it moving? The Planck’s con-
stant is 6.62607 × 10−34 J · s .
Answer in units of m/s.
013 (part 2 of 2) 10.0 points
If the electron has a speed of 9 × 106 m/s,
what is its wavelength?
Answer in units of m.
Thats what I need help on.
I tried E = hc / λ
Then E = 1/2mv^2
But that didnt work. Any ideas? Thanks
Use the de Broglie relation between momentum p and wavelength λ:
λ=h/p.
ehild
OK you're not too far off the right method so that's good :smile:
So these are the things you already know:
Planck's Constant: h=6.62607\times 10^{-34} J s^{-1}
Electron Wavelength: \lambda_{e} = 4.4\times 10^{-7} m
For the first part you need to find the velocity of the electron.
As ehild said you should use the de-Broglie relation for the wavelength of an electron, which is:
\lambda = \frac{h}{p}
You can just quickly look up the mass of an electron (if you can't remember it) and then you know everything you need to know in order to calculate the speed of the electron, through inputting the values and rearranging the equation.
For the second part you are now given the electron speed and need to find wavelength. This is a similar method just slightly different.
So now you know:
Electron Speed: v = 9\times 10^{6}ms^{-1}
Again you can use the de-Broglie relation, just rearrange it as required, input values, and there you go. :biggrin:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
