Finding electrostatic potential
To find the energy stored in a solid sphere, the integral for energy, U, is set up using the electric field equations for two regions: inside the sphere (0 < r ≤ R) and outside (r > R). The first integral correctly incorporates the electric field squared for the region inside the sphere, while the second integral for the region outside needs the electric field squared as well. Additionally, it is important to include the angular components in the volume integrals. The discussion emphasizes the need for careful setup to ensure accurate calculations. Proper integration will yield the total energy stored in the sphere.
ghostfolk
Find the energy stored in a solid sphere by integrating ##\frac{\epsilon_0}{2} \int E^2d^3r## given that ##E=k\frac{r^2}{4 \epsilon_0}## for ##0<r\le R## and ##E=k\frac{R^4}{4r^2 \epsilon_0}## for ##r>R##
##U=\frac{\epsilon_0}{2} \int E^2d^3r##
I'm just looking for the correct set up
##U=\frac{\epsilon_0}{2} [\int_0^R (k\frac{r^2}{4 \epsilon_0})^2d^3r+\int_R^\infty (k\frac{R^4}{4r^2 \epsilon_0})d^3r]##.
With the given fields, your setup is fine apart from missing a square of the field for the second integral. Also, do not forget the integrals in the angles.
