Finding energy eigenvalue of a harmonic oscillator using a Hamiltonian
7 replies · 3K views
JordanGo
Find the energy eigenvalue.
H = (p^2)/2m + 1/2m(w^2)(x^2) + λ(x^2)
Hψ=Eψ
So this is what I got so far:
((-h/2m)(∂^2/∂x^2)+(m(w^2)/2 - λ)(x^2))ψ=Eψ
I'm not sure if I should solve this using a differential equation method, or is there an easier trick?
Thank you!
... you should solve using the DE methods.
Since the potential is in x only, the partials become exact[1]:
$$\left ( \frac{-\hbar^2}{2m}\frac{d^2}{dx^2} + \zeta x^2 - E \right )\psi(x) = 0 : 2\zeta = m\omega^2+2\lambda$$... and it is really useful for these things to learn to use ##\LaTeX## :)
Note: You had:
I don't know why you didn't square your ##\hbar## or why you have a ##-\lambda## in there but the setup has a ##+\lambda##.
Also, I'm guessing by "##h##" you meant ##\hbar=h/2\pi## since the momentum operator is ##-i\hbar\frac{\partial}{\partial x}##.
[1] if you are expected to do this in 3D, then you'll have to deal with the other two directions.
Ok, so now I tried to perform the differential equation, but then I get an equation in the form of:
Ψ=Ae(ς-E)x+Be(-(ς-E)x)
How can I find the energy eigenvalue from this equation?
You put it into the Schrödinger equation and solve for E.
But I am not sure that wavefunction is a solution... don't you associate Gaussians with harmonic oscillator potentials?
We haven't done any sort of Gaussian...
But I came up with another way to solve, can you see if this makes sense:
I can write the Hamiltonian as:
[itex]H =\frac{p^2}{2m} + x^2 (\frac{m\varpi^2}{2} + \frac{\lambda}{\sqrt{2}})[/itex]
or
[itex]H = \frac{p^2}{2m} + \frac{mω'^2x^2}{2}[/itex]
where
[itex]ω'=\sqrt{ω^2+\frac{\sqrt{2}λ}{m}}[/itex]
then I can use
[itex]E = (\hbar)ω'(n+\frac{1}{2})[/itex]
Sure - you can exploit existing solutions. What what stopping you from writing ##m\omega^{\prime 2} = \zeta## before? (and using the same trick?)
Good point! I can also do it that way, I'll try it out.
This problem involves a 2D harmonic oscillator (which the Hamiltonian was for x). To find the degeneracy of the first excited state, can I state that since ωx=ωy=ω, that n = nx + ny.
Then I can write ny=n - x, and set up the following sum:
[itex]\sum(n-n_{x}) = \frac{1}{2}n(n+1)[/itex]
where the sum is from nx=0 to n.
So, using the equation to solve for n=1 (first excited state), I get the degeneracy is equal to 1. Is this correct or am I missing something?
