Finding force to accerate with given speed and time
  • Thread starter Thread starter tutojean
    Force Speed Time
To determine the force required to accelerate a 1000 kg automobile from 10 m/s to 50 m/s in 8 seconds, the correct approach involves calculating the acceleration first. The change in velocity is 40 m/s, and dividing this by the time of 8 seconds gives an acceleration of 5 m/s². Using the formula F = ma, the necessary force can be calculated as F = 1000 kg * 5 m/s², resulting in a force of 5000 N. The initial attempt incorrectly calculated the force without properly determining the acceleration. Understanding the relationship between force, mass, and acceleration is crucial for solving such problems.
tutojean
An automobile of mass 1000 kg is traveling 10 m/s. What force is necessary to accelerate it to 50 m/s in 8 sec?
Used Sigma(F) = (m)(a)
Sigma F = force
m = mass
a = acceleration
F = ma
Sigma F = (1000)(50-10)
And that number is way too high. I don't really know how to approach this problem or even what I should use. Please help. Thank You.
First you need to calculate the acceleration properly. 50-10 m/s is the change in velocity. What's the acceleration?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
