Finding if a Series is Convergent
  • Thread starter Thread starter I'm Awesome
    Convergent Series
The discussion revolves around determining the convergence of the series \(\sum \frac{k}{1+k^2}\). Participants are exploring various convergence tests to assess the series' behavior.
  • Participants initially consider the ratio test but question its applicability after receiving feedback. Some suggest alternative tests such as the integral test and comparison test, while others express uncertainty about which test to use.
There is active exploration of different convergence tests, with participants sharing insights and clarifying common misconceptions about the nth term test for divergence. Some guidance has been offered regarding the suitability of various tests, but no consensus has been reached on the best approach.
Participants note that the series is not an alternating series or a p-series, which influences their choice of tests. There is also mention of a common mistake regarding the implications of the nth term approaching zero.
I'm Awesome
Does [itex]\sum[/itex][itex]\frac{k}{1+k^2}[/itex] converge?
What I'm basically doing is using the ratio test. And at the end I get that the limit goes to ∞.
Therefore it it is convergent. But I'm not sure if I'm using the right test or if an other test would be easier.
Without seeing your work, who knows where you went astray. I don't think the ratio test will help you on this problem. What other tests have you thought of trying?
If you're getting ∞ as an answer, then the series diverges, not converges.
Okay this is what I did. I decided not to use the ratio test anymore.
http://img341.imageshack.us/img341/5567/calculus.png
What you have done is pointless. Noting that the nth term of a series goes to zero tells you nothing about convergence of the series.
There are other tests for convergence/divergence than the ratio test. What are they?
I would try an Integral test. Always the best for "easy functions" cause you can't over think and make a mistake.
Comparison test, integral test, p-series test, root and ratio tests, and the alternating series test.
I'm just not sure which on to use. I know it can't be an alternating series, or p-series.
Use the comparison test or the limit comparison test.
Let [itex]u_k=\frac{k}{1+k^2}[/itex]
Then, [itex]v_k[/itex] can be approximated to ... as k tends towards infinity.
To elaborate on what LCKurtz said, the nth term test for divergence says something like this.
"If ##\lim_{n \to \infty} a_n \neq 0##, the series Ʃ an diverges."
This test can tell you only whether a series diverges. It is a very common mistake that students make when they conclude from this test that a given series converges. In other words, if ##\lim_{n \to \infty} a_n = 0##, you cannot conclude that the series converges.
Example: [itex]\lim_{n \to \infty} \frac{1}{n} = 0[/itex] but it diverges! (it's a harmonic series).
Good example.
Another example is ## \lim_{n \to \infty} \frac{1}{n^2} = 0##. Same result, but this time the series converges.
Thank you for clarifying this common mistake, Mark44. I made that error not so long ago in my test.:redface: I blame it on stress.:rolleyes:
OK. Well I have already told you the ratio test won't work and you see it isn't an alternating series. It isn't a p series. So that leaves comparison and general comparison test and integral test. So try something.
Okay, I tried the integral test. Does that answer look better now?
Therefore, the seires is divergent by the integral test.
Looks fine.
The integral test works nicely. Though what I'd do is the Ratio Test. Nice solution! Really, really nice.
Which, as I have mentioned before, would be inconclusive.
Yes. See, all you had to do was try it. Good writeup.
