Finding Loci of Centres in Ellipses: Can You Help?
  • Context: Undergrad
  • Thread starter Thread starter gianeshwar
    Ellipse
The discussion revolves around finding the loci of various centers of triangles formed by a point on an ellipse and its two foci. Participants explore methods for determining the locus of the incenter, centroid, circumcenter, and orthocenter of such triangles, discussing both theoretical approaches and practical calculations.
  • One participant asks for references to find the loci of various centers of triangles formed by a point on an ellipse and its foci.
  • Another participant corrects the use of "locii" to "loci" and suggests writing an equation for the locus as the point on the ellipse moves.
  • It is noted that the center of the triangle can be found by averaging the coordinates of the vertices, with specific coordinates provided for the foci and a point on the ellipse.
  • A participant expresses confusion over obtaining a parabola as the locus of the incenter, suggesting it does not align with their physical understanding.
  • Another participant challenges the parabola result, asking for clarification on the calculations leading to that conclusion.
  • One participant confirms that they found the centroid locus to be an ellipse, while expressing ongoing confusion about the incenter locus.
  • Further details are provided about the definitions and formulas for the incenter, circumcenter, orthocenter, and centroid, with links to external resources for more information.
  • Participants discuss graphical representations and refer back to previous images shared in the thread for verification of results.
Participants express differing views on the locus of the incenter, with some finding it to be a parabola while others dispute this result, suggesting it should be an ellipse. The discussion remains unresolved regarding the correct locus for the incenter.
Participants mention various mathematical steps and assumptions, but there are unresolved aspects regarding the calculations for the incenter locus and its physical interpretation. The discussion includes references to specific formulas and graphical representations that may not be fully explored.
gianeshwar
Dear Friends!
If we have a variable triangle formed by joining a point of ellipse and its two focii shown in figure,how to find locii of various centres.Can you please suggest some reference to find these .I have tried by using simple method for incentre locus which I left as it goes long. Though I am still thinking.
Mathematics news on Phys.org
gianeshwar said:
View attachment 87310 Dear Friends!
First off, locus is singular and loci (one 'i') is plural, not "locii."
For your ellipse, the two foci are at ##(\pm c, 0)##, where ##c = \sqrt{a^2 - b^2}##). Possibly you could write an equation for the locus of the various centers as the point P on the ellipse moves around.
The center of such a triangle is the point whose coordinates are the means of the corresponding coordinates of the vertices.
Here, you have a ellipse given by [itex]\frac{x^2}{a^2}+ \frac{y^2}{b^2}= 1[/itex]. Assuming that a> b, the two foci have coordinates [itex](-\sqrt{a^2- b^2}, 0)[/itex] and [itex](\sqrt{a^2- b^2}, 0)[/itex]. You can write a point on that ellipse as [itex]P= (a cos(t), b sin(t)[/itex] for parameter t between 0 and [itex]2\pi[/itex]. "Average" those coordinates.
(That turns out to be remarkably simple and gives a very easy answer!)
Thanks Mark44 and Hallsoflvy!
Dear friends ! In the solution of finding locus of incentre ,I am getting parabola as locus which does not seem to be by physical picturization.
Well, what did you do when you followed our suggestions? What is the "average" of the three points [itex](-\sqrt{a^2- b^2}, 0)[/itex], [itex](\sqrt{a^2- b^2}, 0)[/itex], and [itex](a cos(t), b sin(t))[/itex]? It is NOT a parabola! Please show exactly what you did.
Thanks Hallsfloy! I believe you are telling to find centroid locus which I am showing now. It is an ellipse which is fine.The first locus which I had calculated was of incentre in attached picture earliar.
Yes, that's right. As I said originally, "That turns out to be remarkably simple and gives a very easy answer!" The y coordinates of the first two points are 0 and their x coordinates cancel so the equation of the locus is just the original ellipse, divided by 3. It is the ellipse with major and minor axes 1/3 the length of the original ellipse.
Thanks! Now my doubt in #6 is still left!
What "doubt" do you mean? The difficulty you stated in #6 was that you got a parabola which, of course, can't be right because a parabola would have to go outside the original ellipse. But in #8 you say you got an ellipse as the answer.
Incenter is the intersection point of bisector lines of the angles of the triangle
Circumcenter is the intersection point of the sides perpendicular bisectors
Ortocenter is the intersection point of the height
Centroid is the intersection point of the medians
The average of the coordinates gives the centroid.
The other points are less trivial to find
Incenter can be found using the formula here http://www.mathopenref.com/coordincenter.html
Circumcenter P has coordinates
[tex] x_P=\frac{{x_A}^2 {x_B}-{x_A}^2 {x_C}-{x_A} {x_B}^2+{x_A} {x_C}^2-{x_A} {y_B}^2+{x_A} {y_C}^2+{x_B}^2 {x_C}-{x_B} {x_C}^2+{x_B} {y_A}^2-{x_B} {y_C}^2-{x_C} {y_A}^2+{x_C} {y_B}^2}{2 (-{x_A} {y_B}+{x_A} {y_C}+{x_B} {y_A}-{x_B} {y_C}-{x_C} {y_A}+{x_C} {y_B})}<br /> [/tex]
[tex] y_P=<br /> \frac{{x_A}^2 ({x_C}-{x_B})+{x_A} \left({x_B}^2-{x_C}^2+{y_B}^2-{y_C}^2\right)-{x_B}^2 {x_C}+{x_B} \left({x_C}^2-{y_A}^2+{y_C}^2\right)+{x_C} ({y_A}-{y_B}) ({y_A}+{y_B})}{2 ({x_A} ({y_B}-{y_C})+{x_B} ({y_C}-{y_A})+{x_C} ({y_A}-{y_B}))}[/tex]
Orthocenter O has coordinates
[tex] x_O=\frac{{x_A} ({x_B} ({y_B}-{y_A})+{x_C} ({y_A}-{y_C}))-({y_B}-{y_C}) ({x_B} {x_C}+({y_A}-{y_B}) ({y_A}-{y_C}))}{{x_A} ({y_B}-{y_C})+{x_B} ({y_C}-{y_A})+{x_C} ({y_A}-{y_B})}[/tex]
[tex] y_O=\frac{{y_C} (-{x_A} {y_A}+{x_B} {y_B}+{x_C} ({y_A}-{y_B}))+({x_A}-{x_B}) (({x_A}-{x_C}) ({x_B}-{x_C})+{y_A} {y_B})}{{x_A} ({y_B}-{y_C})+{x_B} ({y_C}-{y_A})+{x_C} ({y_A}-{y_B})}[/tex]
It can be quite hard to work it out...
Graphically it can be seen as in the following picture
I am referring to my first picture where I have evaluated locus of incentre.
Picture in #5
Thanks Raffaelel! I have calculated incentre locus in attached image in #5.Need to get it verified.
  • · Replies 125 ·
21K
  • · Replies 42 ·
