Finding Magnetic Field from a Current Bearing Conductor
A long, thin conductor carrying a current of 8.93 A generates a magnetic field of 4.79 × 10−5 T at a certain distance. The initial attempt to calculate this distance used an incorrect formula, confusing it with one for parallel conductors. After correcting the formula to B = μ₀ * I / (2 * π * d), the user recalculated and initially arrived at 1.1869 m, which was incorrect. Further checks led to the correct answer of 3.7286 cm after resolving calculation errors. The discussion emphasizes the importance of using the right equations and careful arithmetic in physics problems.
mba444
A long, thin conductor carries a current of
8.93 A.
At what distance from the conductor is
the magnitude of the resulting magnetic field
4.79 × 10−5 T? Answer in units of cm.
B= Uo*I*l/(2*pi*d)
i used this equation to figure out the distance but i keep getting the wrong answer
can someone explain wats going wrong ?!
thanx
8.93 A.
B= Uo*I*l/(2*pi*d)
thanx
What is the l in your equation?
its the length
mba444 said:
its the length
Well, the formula is incorrect, which probably explains why you've been getting the wrong answer. How did you arrive at that particular formula?
As an aside, what have you been using for the length of the wire since the question does not specify how long the conductor is?
Oops
i mixed up the parallel conducters equation with the straight wire equation
therefore is this the one B=Uo*i/2*pi*d
mba444 said:
Oops
That looks good to me.
wrong answer !
d=(4*pi*10^-7*8.93)/(2*pi*4.79*10^-5)= 0.011869 this is in meters so i converted it into cm i got 1.1869
mba444 said:
wrong answer !
I'd recheck your arithmetic and make sure that you are punching the numbers into your calculator correctly.
i did checked it again but still the same answer
Well using your numbers I get a different answer. You must be punching the numbers into your calculator incorrectly.
oka i got 13.0501 cm after correct my calculation but still the answer is wrong !
Still not the same answer as I get. All I can suggest is that you check the manual that came with your calculator to ensure that you are entering the numbers correctly.
i figured out my mistake thanks for your help
the answer is 3.7286 cm
