Finding Magnetic Fields on the x-axis for Two Dipoles on the z-axis
  • Thread starter Thread starter mateomy
    Dipoles Magnetic
mateomy
I'm given two magnetic dipoles on the z-axis with a separation of a distance L. I need to find the fields produced by the individual dipoles at a point on the x-axis in terms of x.
This problem is driving me nuts. I've drawn a diagram with the radial vector going from the z-point to the x-axis at a given point, P. The angle between the radial vector and the z-axis has been labelled as \theta. What I've done so far is calculate the vector potential (\overrightarrow{A}) and I think I'm confusing myself because I've produced two expressions; one for \hat{y} and another for \hat{z}, but absolutely nothing for the x-component. My expression so far is:
For \hat{y}:
<br /> \frac{x}{r^3}<br />
For \hat{z}:
<br /> \frac{1}{r^3}<br />
*I've left out some constants
I'm not sure I've done that correctly, regardless I went to take the curl of these vector potential expressions \nabla\times\overrightarrow{A}, which only gave me expressions in the y and z directions. That doesn't seem right to me, but I wanted to take it to Physics Forums to get some advice. I'll show more detail if its found necessary, I'm mostly curious to see if the expressions for the vector potential make sense.
Thanks.
I would not use the vector potential here. Just take the formula of a magnetic dipole, shift it by -L/2 and do the same for just another one at +L/2 to find the field by superposition.
Really, there is no difference to electric dipoles from the perspective of the fields.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
