Finding magnitude and direction of reaction force
The discussion focuses on calculating the magnitude and direction of the reaction force at the hinge of a uniform horizontal rod with a mass of 4 kg and a length of 500 mm, supported by a chain located 10 cm from the hinge. The principle of moments is initially considered but deemed inappropriate due to the one-sided nature of the load. Instead, resolving the system into vector components is identified as the correct approach to determine the resultant force at the hinge. The static equilibrium condition is emphasized, indicating that any point can be used for moment calculations.
  • Understanding of static equilibrium principles
  • Knowledge of vector resolution techniques
  • Familiarity with the concept of moments in mechanics
  • Basic knowledge of forces acting on rigid bodies
  • Study the principle of static equilibrium in detail
  • Learn about vector resolution in physics
  • Explore the concept of moments and their applications in engineering
  • Review examples of pin-jointed systems in statics
Engineering students, particularly those studying mechanics and statics, as well as anyone involved in analyzing forces in rigid body systems.
SpiraRoam
A uniform horizontal rod of mass 4 kg and length 500 mm, is hinged at the left hand side and supported at rest by a chain (S) attached 10 cm from the hinge.
Calculate the magnitude and direction of the reaction force on the rod at the hinge. State the principle you have used in solving this problem.
Initially I thought it was the principle of moments but it can't be as it's all one sided. Unless there's a moment from the top of the chain to R. It's probably resolving the system into two vector components and then finding the resultant from that but I'm not sure how.
I think that would be the right method?
That would depend on the point about which you are taking moments. Since the situation is static, any point should do.
Suppose the hinge weren't there but the chain remained in place. About which point would the rod pivot?
The information on the virtual learning environment for my college says that all of the necessary information is in the statics and materials document. It doesn't specify anything to do with this particular example though, or perhaps I'm not able to discern what to take and apply from it. It's just talking about pin jointed systems and the likes :/
I'm really not that good at Engineering. ?:) Struggling with a lot of it.
  • · Replies 19 ·
10K
