Finding max and min of a function of several variables
tnutty
Find max/min/saddle point of the function :
F(x,y) = (1+xy)(x+y)
= x^2*y + y^2*x + x + y
F_x = 2xy + y^2 + 1
F_xx = 2y
F_y = x^2 + 2yx + 1
F_yy = 2x
Need help on finding the critical points :
So I have to solve this equations :
F_y = x^2 + 2yx + 1
F_x = y^2 + 2yx + 1
Subtract the two equations and get x^2-y^2=0. That's (x+y)(x-y)=0. Suggests you split the solution into two cases. Can you go from there?
I think its supposed to be (y+x)(y-x). What should I do next?
That function will be 0 when x = y or when x = -yNow do I plug it in into F_x or F_y ?
(x+y)(x-y)=0 and (y+x)(y-x)=0 are both the same condition. Assume x=y and try to solve F_x=0 and F_y=0, any solutions? Now assume x=(-y) and do the same exercise.
So we have :
F_y = x^2 + 2yx + 1
F_x = y^2 + 2yx + 1
and our test case is x = y , -y
case : x = y
F_x = y^2 + 2yx + 1
= y^2 + 2y^2 + 1 = 0
3y^2 = - 1
x = y has no real answercase x = -y
F_x = y^2 + 2yx + 1
= y^2 - 2y^2 + 1
-y^2 = -1
y = 1, -1
so when x = -y , y has to equal -1 or 1 for the function F(x,y) to have a horizontal plane.Using the 2nd derivative test
D = F_xx*F_yy -[F_xy]^2
= (2y)(2x) - (2x + 2y)^2
= 4xy - 4x^2 + 8xy + 4y^2
= xy - x^2 + 2xy + y^2
= y^2 - x^2 + 3xy
so inputting values are (-y, - 1) and (-y , 1)
Case P(-y,-1)
D = y^2 - x^2 + 3xy
= (-1)^2 - (-y)^2 + 3(-y)(-1)
= 1 - y^2 + 3y
0 = y^2 - 3y - 1
Then what, use calculator to find its root?
tnutty said:
So we have :
F_y = x^2 + 2yx + 1
F_x = y^2 + 2yx + 1
case : x = y
F_x = y^2 + 2yx + 1
3y^2 = - 1
case x = -y
F_x = y^2 + 2yx + 1
= y^2 - 2y^2 + 1
-y^2 = -1
y = 1, -1
= y^2 - x^2 + 3xy
Case P(-y,-1)
D = y^2 - x^2 + 3xy
= 1 - y^2 + 3y
0 = y^2 - 3y - 1
Aren't your critical points (1,-1) and (-1,1)? Why are you treating y like some unknown value? I thought you solved for it.
Oh so in this snippet :
case x = -y
F_x = y^2 + 2yx + 1
= y^2 - 2y^2 + 1
-y^2 = -1
y = 1, -1I just input y back into the equation x = -y ?
case x = -y
F_x = y^2 + 2yx + 1
= y^2 - 2y^2 + 1
-y^2 = -1
Sure you do. x=(-y). You assumed that. And with good reason.
Ok thanks then.
I can solve it from here .
So to recap (because it helps me learn better ) I had to do the following.
For the function F(x,y) = ... , find F_x, F_xx, F_xy, F_y , F_yy
Then I had to solve the system of equation of F_x, and F_y, in which I
found the equation x^2 - y^2, which has two cases where it will have a critical point, at x = y and at x = -y.
Inputting this values into F_x or F_y gives me a non real answer for x = y and for x = -y,
it gives me y = -1, 1. So I input those values into the equation x = -y, (question : technically could I have also inputed x = y , -y into the equation F_x or F_y or x^2 - y^2 ? ). From that I have two point , (1,-1) and (-1,1).
With these points I can use the second derivative test to check whether its a saddle point minimum point or a maximum point.
That should be correct , right ?
Sure that's correct. I'm a little unsure what you are unsure about. To be a critical point you need F_x=F_y=0. If F_x-F_y=(x+y)(x-y)=0, then you can certainly conclude that for any critical point either x=y or x=(-y), right?
Yep, thanks for your help. I really appreciate it. I have an exam tomorrow at 9am.
