Finding max. and min. values analytically
  • Thread starter Thread starter lp27
    Max
To find the maximum and minimum values of the function y = 2x^2 - 14x, the first derivative is calculated as y' = 4x - 14. Setting the derivative to zero gives the critical point at x = 7/2. Evaluating the function at this point yields the coordinates (7/2, -49/2). To confirm whether this critical point is a minimum or maximum, the second derivative test can be applied; since the parabola opens upward, the critical point is a local minimum. The discussion emphasizes the importance of analyzing values around the critical point to determine its nature.
lp27
y = 2x^2-14x
y' = 4x - 14
4x - 14 = 0
x = 14/4
f(14/4) = 2(14/4)^2 - 14 (14/4) = -49/2
I don't know how to continue from there. ((14/4), (-49/2)) is my critical point?
lp27 said:
y = 2x^2-14x
y' = 4x - 14
4x - 14 = 0
x = 14/4
there are a couple of steps involved with finding local min/max's:
1) differentiate
2) find f'(x) = 0
3) take values larger and smaller than x | f'(x) = 0 to see if it is a min/max [note: you must do this because you may have f'(x) = 0 without being a min/max]
min: \ /
max : / \
meaning, values less than x | f'(x) = 0 will have negative derivatives if it is a minimum value.. et c .
You can also use the second derivative to determine a local maximum or local minimum. At any critical point c, if f''(c) > 0, there is a local minimum at (c, f(c)). If f''(c) < 0, there is a local maximum at (c, f(c)).
For your particular function, you could also notice that its graph is a parabola that opens upward. The only critical point is at the vertex of the parabola.
BTW you should simplify 14/4 to 7/2.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 36 ·
