Finding maximal total current for a system
  • Thread starter Thread starter Phys student
    Current System
The discussion revolves around calculating the maximal total current for a system of fuses connected in parallel. For part (a), with fuses A and B, the total maximal current is determined to be 1.5 A, as fuse A melts first at 1 A, allowing 0.5 A to flow through fuse B. In part (b), substituting fuse B with fuse C, which has a higher maximal current of 1.7 A, allows the total current to reach 1.7 A, but only after fuse A has melted. This indicates that while the system can handle 1.7 A, it requires the failure of fuse A to redirect the current through fuse C. The key takeaway is that the configuration and characteristics of the fuses significantly impact the total current capacity of the system.
Phys student
a) There are two fuses connected in parallel: fuse A has resistance R_A = 1Ω and
maximal current (by which it melts) I_Amax = 1A; fuse B
has resistance R_B = 2Ω and maximal current (by which it
melts) IBmax = 1.2A. What is the maximal total current for
such a system of fuses?
b) What is the total current when the
fuse B is substituted with a fuse C which has R_C = 2Ω and
I_Cmax = 1.7A?
for part (a) we have:
R_B/R_A = I_A/I_B = 2 because of that fuse A will melt first (the current through it will be 1 A) so we substitute it in the equation and solve for I_B, we get:
I_B = 0.5 A
So:
I = 0.5+1 = 1.5 A
I'm not sure how to do part B
Edit: Answers are: a) 1.5 A
b) 1.7 A
Looks like a mistake in the question to me. Are you sure you've quoted it correctly?
Yes, I'm sure.
Imagine in part (B) current exceeds 1.5 A. What happens then?
Then fuse A would burn and the current would be redirected to fuse C only?
Correct.
voko said:
Correct.
So the answer is 1.7A because after changing to fuse C a larger maximal current is possible where fuse A would burn and the current (1.7A) would be redirected to fuse C only.
1.7 A is possible from the beginning, it is just that fuse A gets blown in the process. This is different from case (a), where the max current is only possible with the two fuses intact.
Likes 1 person
Doh!
