Finding Maximum Current Entering A Terminal
  • Thread starter Thread starter madhatter500
    Current Maximum
To find the maximum current entering a terminal, the charge expression q = 1/α² - (t/α + 1/α²)e^(-tα) is differentiated with respect to time, resulting in the current equation. The first derivative is te^(-tα), and to find the maximum, the second derivative is set to zero, leading to the equation e^(-tα)(1 - αt) = 0. This indicates that the maximum occurs at t = 1/α. The discussion highlights the importance of careful differentiation and algebra in solving for maximum current values. The final answer confirms the correct approach to the problem.
madhatter500
The expression for the charge entering an upper terminal of a component is:
q = 1/\alpha^{2} - (t/\alpha + 1/\alpha^{2})e^{-t\alpha}
Find the maximum value of the current entering the terminal if \alpha = 0.03679 s^{-1}
Since they gave us the equation for the charge, to find current we simply take the derivative with respect to time of the given equation. I did this and ended up with te^{-t\alpha}. This seems to check out just fine. I then realized that they want the maximum value that this derivative can be. So then I went ahead and took the second derivative and tried to set it equal to 0 (since that would be a local max or min). This ended up being very messy and it didn't work out. Is there an easier way to find the maximum current?
Let me know if my mathematics is incorrect, but
\frac{dq^{2}}{d^{2}t}=e^{-t\alpha}-\alpha te^{-t\alpha}=e^{-t\alpha}(1-\alpha t)=0
e^{-t\alpha}\neq0, therefore 1-\alpha t=0
and t=\frac{1}{\alpha}
You can go from there
edit: this is going from your 1st derivative, I haven't checked it myself
Not too comfortable with your first derivative. t appears in two places in the original expression. I think you may have overlooked one??
Perfect. This gives me the correct answer. Looks like I need to brush up on my algebra! Thank you!
  • · Replies 26 ·
