Finding normal force of moving crates
The problem involves calculating the normal force between two crates being pushed along the floor at a constant velocity. The masses of the crates are 49 kg and 29 kg, with a coefficient of kinetic friction of 0.30. The frictional forces acting on each crate are determined using the equation Ff = μkFN, leading to the equations for each crate's normal force. By combining the frictional forces, the total normal force is found to be 23.4 kg, which is then divided equally between the two crates, resulting in a normal force of 11.7 kg for each crate. This analysis illustrates the relationship between mass, friction, and normal force in a system of moving objects.
shahin93
Your moving company runs out of rope and hand trucks, so you are forced to push two crates along the floor as shown in the figure below. The crates are moving at constant velocity, their masses are m1 = 49 kg and m2 = 29 kg, and the coefficients of kinetic friction between both crates and the floor are 0.30. Find the normal force between the two crates.
F = ma
Ff = μkFN
Ff1 = μk1FN1Ff2 = μk2FN2Ff1 + Ff2 = FN1 + FN2 (μk1m1) + (μk2m2) = FN1 + FN2 (0.30)(49 kg) + (0.30)(29 kg) = FN1 + FN214.7 kg + 8.7 kg = FN1 + FN2 23.4 kg = FN1 + FN2FN1 = 11.7 kgFN2 = 11.7 kg
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
