Finding Perimeter/Circumference of part of a circle
  • Thread starter Thread starter sdoyle1
    Circle
To find the perimeter and area of the shaded region between two circles with inner radius 2.9 m and outer radius 6.5 m, and an angle of 110 degrees, the correct approach involves using the formula for circumference and area of an annulus. The total circumference for each radius is calculated using C=2πr, and the arc length is found by multiplying this circumference by the ratio of the angle to 360 degrees. The area of the shaded region is determined by subtracting the area of the inner circle from the area of the outer circle, calculated as π(R^2 - r^2). The expected answers for the perimeter and area are 25.3 m and 32.5 m², respectively. Understanding how the angle affects the calculations is crucial for solving the problem accurately.
sdoyle1
The inner radius is measured from a point A and is 2.9 m. The outer radius is measured from the same point A and is 6.5 m. The angle at A is 110*. What is the Perimeter of the shaded area in meters? What is the area of the shaded are in square meters?
C=2rpi
Just for part A I tried to find the total circumference as if the circle was a full 360* and then multiplied the resulting answer by the ratio of 110*/360*. The answer was incorrect. The answers are suppose to be 25.3 m and 32.5 m^2
C=2rpi
From your description, it seems that you need to find the perimeter and area of a section of a ring or annulus.
The circumference of a circle is C = r * 2pi. The arc length along the portion of a circle subtended by an arc whose measure is theta (in radians) is r * theta.
The area of an annulus is pi(R^2 - r^2), where R and r represent the outer and inner radii respectively.
We know the area of a circle as:
[PLAIN]https://dl.dropbox.com/u/4645835/MATH/Area%20of%20Circle.gif
Part B:
We want to find the area of the shaded portion. So, we find the area of the outside circle and subtract from it the area of the inside circle.
[PLAIN]https://dl.dropbox.com/u/4645835/MATH/Worked.gif
Well, I don't know what the drawing looks like, so I don't know exactly what the problem is. How does the angle of 110 degrees enter into the problem?
I imagine it as a larger circle around a smaller circle. The shaded region they are referring to would be the area enclosed by the two circles. The given angle...according to my interpretation...is between the 0 degree line and the radii extending from point A.
The problem doesn't include a picture?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
