Finding Points of Tangency for the Unit Circle
The discussion focuses on finding the points of tangency for lines from the point P=(3,2) to the unit circle defined by the equation y^2 + x^2 = 1. Participants suggest using the point-slope form of the line and substituting it into the circle's equation to derive a quadratic equation in terms of x and the slope m. The importance of the discriminant in the quadratic formula is highlighted, as it indicates the conditions for tangency. Additionally, the distance formula and Pythagorean theorem are mentioned as tools to relate the distances from the center of the circle to the point P and the tangency points. The conversation emphasizes the need to correctly identify the tangent lines and their corresponding points on the unit circle.
Cascadian
Hi I'm trying to study over break, this isn't an exact quote but its the part of the problem I need help with. Thanks.
Draw the unit circle and plot the point P=(3,2). Observe there are TWO lines tangent to the circle passing through the point P. Lines L1 and L2 are tangent to the circle at what points?
I tried plugging in the point into a point-slope formula, it was kind of a dead end for me.
draw a figure and show what you know
Pick a point on the unit circle, (cos α, sin α) say. Write down the equation of the tangent there.
How about if we get him to draw a diagram first and then help him from there?
Equation for unit circle is y^2 + x^2 = 1. Equation for line passing through point P=(3,2) is y - 2 = m(x-3).
These facts might be helpful. They might also fit under that bold region labeled "2. Homework Equations ".
So, the question is this: if you want to find 2 values for x and y such that both equations are satisfied, what can you do with the two equations? :wink:
Hi everyone, thank you for the input. Let me clarify my situation, I uploaded a diagram; the approach I had been working on was the one Mandelbroth had mentioned. I had y = mx-m3+2 and y^2 + x^2 = 1, when I plugged the first equation into the second I wasn't sure what to do especially because there were now 3 unknown variables, y, x, and m. That's where I'm at now.
The problem with htat approach is that nowhere have you specified that the line is supposed to be a tangent. Do you know how to write down the generic equation for a tangent to circle at a given point, (cos θ, sin θ) say?
Yes, so if you plug y=mx-3m+2 into x^2+y^2=1 then you'll have an equation in terms of x and m. It will be a quadratic in x, so if you solve the quadratic for x, you'll have a solution that is in terms of m.
Now, what you need to do is to understand what the solution to the quadratic is telling you. What does the discriminant in the quadratic formula say?
There is no problem with that approach. He'll be picking the values of m that are tangents to the circle soon enough.
Distance from O to point (3,2) uses distance formula.
Distance from any point on circle to O is 1 for a unit circle.
Two points on the circle are tangency points, upper may be called B, (x2, y2).
Angle of triangle at B is right-angle, so POB is right triangle.
Distance from B to point (3,2) uses Pythagorean Theorem, because you know the other two triangle side lengths.
Use DISTANCE FORMULA again for B to point (3,2).
Two equations and unknowns:
x2+y2=1
BP=sqrt((3-x)2+(2-y)2)
