Finding potential difference between two points on a cone
3 replies · 8K views
issacnewton
Hello
I am solving some problems from "Intro to EM" by David Griffiths ( third edition)
Problem 2.26 ( attached file 2.26.jpg) and I have also attached the solution from the solution
manual (griffiths-2.26.jpg). For both part a and b I am getting different answer.
I have chosen vertex as the origin and the axis of the cone as the positive z-axis.
The bottom of the cone is toward positive z axis. Now any differential area element on the cone would be (using cylindrical coordinates) , x*d(phi)*dz , where x is the perpendicular
distance of the area element from the z-axis. But for this geometry, x=z for any point on the
cone , so dz = dx. The distance r of this area element from the origin(vertex) would be
sqrt(2)*x. I am supposed to use the formula (formula.jpg).
Why are my solutions not working ? Or is the instructor's solution manual incorrect ?
Regards
I Newton
Hello IssacNewton! :smile:
I can see the instructor's solution but not your solution. :confused:
hello tiny-tim
i will write my solution though i just explained what i did. i see people here write using LateX. how can i write like that ? is there any 'How to' tutorial for doing that ?
Newton
(just got up :zzz: …)
LaTeX is very easy.
The best way to see how to use it is click the "QUOTE" button on someone else's post and copy what they do. :wink:
There's a list of symbols and a guide at http://www.physics.udel.edu/~dubois/lshort2e/node61.html#SECTION008100000000000000000"
and there's also a palette of symbols if you click the ∑ tag just above the Reply box (though I never use it).
