Finding quantity of energy stored in a spring
  • Thread starter Thread starter Benzene_ring
    Energy Spring
The discussion revolves around calculating the energy stored in a spring, specifically focusing on two parts: determining the work done to stretch the spring and finding the energy stored when stretched a specific distance. The subject area includes concepts from mechanics, particularly related to elastic potential energy.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the method for calculating work done on the spring and the formula for elastic energy. There are questions about unit conversions and the spring constant, as well as the correctness of the calculations performed.
The discussion is active, with participants sharing their calculations and questioning the assumptions made regarding units and values used. Some guidance has been provided regarding the need to convert units to standard form, and there is an ongoing exploration of the correct approach to find the energy stored in the spring.
Participants are addressing the importance of unit consistency, particularly converting centimeters to meters for calculations involving the spring constant and energy. There is also a note about needing to revise answers based on these conversions.
Benzene_ring
Hey guys, I'm having some trouble finding the exact quantity of energy storied in this spring problem.
It's like a problem with parts A and B, part A says "Determine the amount of work required to stretch the spring from 0 to 20 cm. I found that to be 125J. For Part B, it says "Suppose that this spring was stretched 7.753 cm. Find the exact quantity of energy stored in the spring.
I think that the equation that i would use is the one for elastic energy, Ee= 1/2kx^2
So far i have Ee= 1/2kx^2
Ee= 1/2k(7.753)^2
I'm not sure if I'm doing this right, or what to do next.
Thanks
How did you solve part A?
For part A, it had a diagram and the displacement was 20 cm and the force was 12.5N so i calculated 20*12.5/2= 125J
I assume that the 12.5 N force was the force required to stretch the spring 20 cm. So what's the spring constant?
Careful with units! (Convert distances to standard units: m, not cm.)
I divided 12.5 by 20 and got 0.625, but should i have converted before dividing?
Yes. You want k in N/m, not N/cm.
(Note that you'll have to revise your answer for part A.)
Ok, i think i got the right answer.
Ee= 1/2 (625)(0.0078)^2
Ee= 1/2(625)(0.00006)
Ee= 0.01875J
Thank for all the help!
Ee= 0.01875J
Careful! (But you're almost there.)
Check your values for k and for the amount of stretch.
  • · Replies 17 ·
  • · Replies 20 ·
