Finding reaction forces in a truss
  • Thread starter Thread starter Paladashe
    Moments Trusses
17 replies · 4K views · last reply
Paladashe
Hi, I'm new on this website and it seems great :p So, I'm struggling with something really simple... trusses analysis. I'm struggling with moments etc , I've just drawn an example linked in this post , could you try to find the reaction forces (roller pin etc) with some explanation ? Thanks
Hi Paladashe! Welcome to PF! :wink:
(please use the homework forum in future)
If I'm understanding the question correctly, no truss analysis is involved …
you have a rigid body with one applied force (plus its own weight), and you have to find the two reaction forces, so just use linear components of force, and moments …
show us what you get. :smile:​
Thanks Tiny-tim for your response. In fact, I now for vertical external forces and horizontal ones so I divided the 100N vector in two vectors (one with a value of 50N orientated downwards and one with a value of 50•(square root of 3). I found that each pin has a vertical vector orientated upwards with a value of 25 N and for the fixed one, also an horizontal vector with a value of 50•(square roots of 3 orientated to the left). Am I right? I'm sure that I've made some mistake...what value did you find?
Hi Paladashe! :smile:
Correct. :smile:
I found that each pin has a vertical vector orientated upwards with a value of 25 N…
Nooo …
you can't assume they're equal, can you?
all you know is that they add to 50N, so you need one more equation, which is … ? :wink:
The moment equation, right?
... EMa=-50•3•12,1244 + 50(square root of 3)•7 + 4•12,1244•Rb ?
Yes. :smile:
(either about A or about B)
(where 12.1244 = 14*√3/2)
Yes …
or you could avoid splitting the 100 N by doing 100 times the lever arm (the perpendicular distance from the line of the 100 N to the point A). :wink:​
Yes but don't know how to do this because its not perpendicular to the line of action:)
Yes, but by doing my equation , I found that Rb=50N so R(vertical) is equal to 0??
yes but it's not working for me :p could you please try to explain why my equation is wrong ? Please ! I'm getting a headache by trying and trying :p
Paladashe said:
Yes, but by doing my equation , I found that Rb=50N …
I don't get 50 :confused:
i mean, using your equation (which is a little confusing :redface:) i don't get 50
No as you said before, we can't assume that both pin have the same vertical forces (25-25). Or, if Rby is equal to 25 and that EFy=0 <=> -50+25+Ray=0 :) so Ray is equal to 0 which is impossible
(just got up :zzz:)
yes, we can't assume it …
but that doesn't mean that we can't prove it (if it's true) :wink:​
not following you …
doesn't -50+25+Ray=0 mean Ray = 25 ? :confused:​
