Finding speed of a string given length, mass, and velocity of wave
The problem involves two strings of equal length but different masses, with a wave traveling at 5.0 m/s along the first string. The correct approach to find the speed of the second string is to use the equation v=sqrt(T/μ), where T is tension and μ is linear mass density. The first string has a linear mass density of 0.06 g/cm, while the second string, having half the mass, has a density of 0.03 g/cm. Since both strings are under the same tension, the speed of the second string remains 5.0 m/s. Thus, the speed of the second string is the same as the first.
mandy9008
A string is 50.0 cm long and has a mass of 3.0 g. A wave travels at 5.0 m/s along the string. A second string has the same length, but half of the mass of the first. If the two strings are under the same tension, what is the speed of the second string?
I don't know which equation to start with. I tried to find omega (w) using w=sqrt(g/l) and then using v=wrt. I don't think this is right. Can someone point me in the right direction?
The correct equation is v=sqrt(T/μ), where T is the tension and μ is the linear mass density (mass divided by length). In this problem, the linear mass density of the two strings is different, so the velocity of the second string will be different. The linear mass density of the first string is 3.0 g/50.0 cm = 0.06 g/cm. The linear mass density of the second string is half of that, so it is 0.03 g/cm. Plugging these values into the equation, we get v = sqrt(T/0.03 g/cm) = sqrt(T/0.03) m/s. Since we know the tension is the same in both strings, the speed of the second string will also be the same, 5.0 m/s.
