Finding speed of water flowing in a pipe with changing diameter
The discussion revolves around calculating the speed of water flowing in a pipe with varying diameters. The initial conditions state that water flows at 1.5 m/s with a diameter of 4 cm at point 1 and 3 cm at point 2. The conservation of mass principle is applied, leading to the equation v1*A1 = v2*A2 for volumetric flow rate. Confusion arises when the user mistakenly uses diameters instead of cross-sectional areas, resulting in incorrect calculations. Ultimately, correcting the use of areas yields the correct speed of 3.92 m/s at point 2.
aija
Water flows in a pipe with speed 1.5 m/s at point 1.
The diameter of the pipe at point 1 is 4cm and the diameter at point 2 is 3cm.
density of water: 998.2071 kg/m^3
What's the speed of the water at point 2?
I think you need to use this. I just have no idea how to find pressures p_1 and p_2 which seems to be needed to get the solution v2 out of this:
p_1+0.5ρ(v_1)^2 = p_2+0.5ρ(v_2)^2
Trying to find the pressure difference p_2 - p_1
At this point I realize it's impossible because you need to use the equation above and it's also needed to solve v_2. No idea what else I could do.
If you assume conservation of matter (water will not spontaneously appear or disappear in the pipe system) and unchanging density then what can you say about the volumetric rate of flow of water past any two given points? Can you calculate the rate of flow?
Thank you I got it. So the volume flow rate vA is constant so
v_1*A_1=v_2*A_2
V_2=-(v_1*A_1)/A_2
Still getting a wrong answer. Is something wrong in my equation?
with values
A_1 = 3.5 cm
A_2 = 2.5 cm
v_1 = 2.0 m/s
i get 2.8 m/s and it's wrong.
the correct answer was 3.9 m/s. But why did I get a wrong answer?
with values
A_1 = 3.5 cm
A_2 = 2.5 cm
v_1 = 2.0 m/s
Those look like different values from those in your original post. Are A_1 and A_2 supposed to be cross sectional areas or diameters? (The given units suggest diameters).
If they are diameters then they lead to a result of 3.92 m/s .
Oh thanks. I accidentally used diameters as areas...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
