Finding Tennis Racquet String Tension
  • Context: High School
  • Thread starter Thread starter anirudhreddy
    String Tennis Tension
6 replies · 4K views
anirudhreddy
Could you guys please tell me a very lab-doable method for finding the tension of the strings of a tennis racquet?
thx
Yup. i play tennis with that racquet
I don't think it can be done via an algorithm. You'd have to actually restring a racquet with various tensions and then measure how much the strings flex when a force is applied to the center of the racquet and curve fit the results. Even this may change over time due to friction and wear of the strings.
I'm also not sure if the strings "relax" after the initial stringing of a racquet. Players find a stringing tension they like and stick with that. Current racquets, the new polyester strings, and stringing machines are pretty accurate compared to older times when you could see players bouncing the edge of a racket against the strings of another racquet to choose which one to play with.
If you know the mechanical properties of the 'head', be it wood, fibreglas, carbon fibre, or whatever... maybe you can do distortional measurements with and without the strings to see how much deformation they cause?
From the other end, if you know the physical properties of the strings themselves, you can perhaps do deformation measurements of the 'web?' under various load conditions.
I'm just pulling stuff out of my ass here, though, because I really don't know anything about the subject.
thx
1. Pluck the string, and measure the frequency of vibration. Then use physics.
2. Clamp the string. Measure the force required to pull it the slightest amount.
Compare.
