Finding the angle of the total acceleration of a point?
To find the angle of total acceleration for a point on a rotating turntable, the radial acceleration is 1.25 m/s² and the tangential acceleration is 0.4096 m/s². The total acceleration is calculated as 1.31 m/s². The angle can be determined using the arctangent function, specifically tan^-1(tangential acceleration/radial acceleration). Clarification is needed on whether the angle is measured relative to the radius or an initial coordinate direction, as this affects the calculation. The speed of the point does not influence the angle, which is derived solely from the vector components of acceleration.
JessicaJ283782
A point on a rotating turntable 21.5 cm from the center accelerates from rest to a final speed of 0.740 m/s in 1.80 s. At t = 1.26 s,
I found:
Radial Acceleration: 1.25
Tangential Acceleration: .4096
Total Acceleration: 1.31
Now, I'm having problems finding the total acceleration angle?
I did:
.740/1.80=.411
tan^-1(.411/1.25) and I got 18.2, but that isn't right?
Thank you!
You haven't specified a reference frame for the angle. Is it the angle to the radius or to some initial coordinate direction?
Assuming it's to the radius (or, equivalently, to the tangent), the speed has nothing to do with it. You have the radial and tangential components of the acceleration as a vector; you just need to figure out the direction of the vector.
