Finding the area between 2 curves
  • Thread starter Thread starter ntox101
    Area Curves
ntox101
a.) Find the area of the region bounded by the graphs of f(x) = 1/x and 2x+2y=5
b.) Also, use the shell method to setup the integral that represents the volume of the solid formed by revolving the region bounded by the two same graphs about the y= 1/2. (Do not evaluate the integral)
For area between two curves : Integral[f(x) - g(x)] dx (depending on which curve is on top)
For shell method : 2pi Integral[ p(x) h(x) ] dx
a.) What I did was take the second equation (2x+2y=5) and solved for y to make (y = (5-2x)/2). I then made Integral[ ((5-2x)/2) - (1/x) ] dx. For [a,b], I just used the zoom function on my calculator and got a = 1/2 and b = 2. (I'm not sure if it is correct or not) After integrating, I got 1/2[5x-x2-ln|x|]
b.) I haven't been able to get this setup to the way that I think is correct. My answer is
2pi Integral[ ( (5-2y)/2 ) * (2- (1/y)) ] dy . (with a = 1/2 and b = 2). I think my [a,b] are wrong because this is in terms of y, not x, since we are revolving around the y-axis.
Also, without using Mathematica, how can I use the Integrand symbols to make this look more presentable?
Thanks,
Jon
For a) it looks right. By the looks of it, you are also right about the intersection points, although it would be neater if you proved that (set 1/x equal to (5 - 2x)/2 and solve for x) or at least say that you read off 1/2 and 2 and plug them into 1/x and (5 - 2x)/2 to show that they are indeed intersection points.
For b), you might find this link helpful.
For part (a) i got 1/2[5x-x^2]-ln|x|
For part (b) to revolve around y-axis you need to turn the equation into x^2 = f(y)
and since you are revolving around y=1/2, you need to substitute x^2 = f(y-1/2).
Hope that helps
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
