Finding the Best Pump for Nickel Slurry Transport
For transporting a nickel slurry with a mass flow rate of 27 kg/s and a density of 1218 kg/m^3, a medium-duty slurry centrifugal pump is recommended. The required flow rate is approximately 0.022 m³/s, and the total head, factoring in friction and discharge pressure, could reach 10-15 meters. The hydraulic power requirement is calculated to be around 2.7 kW, with a suggestion to include a safety factor for the motor size. Sizing slurry pumps involves more complexities, including NPSH, head derating, and viscosity considerations. Schur Pump Company is noted for providing cost-effective and high-quality slurry pumps suitable for such applications.
sdlee
hi guys.
I need some basic information about a pump that will be able to transport a nickel slurry up around 1-2m high. the mass flow rate of the slurry is 27 kg/s with a density of 1218 kg/m^3. the temperature of the slurry is 25 deg c.
What is the best type of pump to use in this instance? what sort of power requirement will it have? what does a pump like this cost?
thanks in advance.
U require a medium duty slurry centrifugal pump for your application.
The most basic reqs to size a pump are flowrate & pressure head.
In your case FLOWRATE =27kg/s/1218kg/m3 = 0.022m3/s.(79.2m3/hr)
Your HEAD = 1-2m + (friction head) + discharge pressure (im metres)
if the discharge line is short and you discharge at atm pressure, your head may come to 10-15m.
In which case Hydraulic Power reqd = FLOW (m3/s) * Head (Pa) = 0.022 * 10 *1218 *9.8 = 2.7kW
Place some safety factor (on the motor size ONLY)
Look at a manf curve book to find the pump meeting your specs.
The proper way to size slurry pumps however is much more complex than this. U mus consider NPSH, head derating, viscosity, pipe friction etc.
thanks for the answer.
Appreciated.
Steve.
Located in Jacksonville, Florida and established in 1975, Schur Pump Company has been manufacturing and repairing pumps for over 30 years. Our vision is to be a key force in providing cost effective high quality new pumps, re-manufactured pumps, pump parts, pump repairs, pump solutions and customer support for abrasive and corrosive applications.
When you evaluate a Schurco Slurry Pump based on all the criteria, you find that it is the best and least expensive pump to use.
http://www.schurcoslurry.com
