Finding the Coefficiant of friction
  • Thread starter Thread starter BlakcDahlia
    Friction
The discussion centers on calculating the coefficient of friction for a cart weighing 1.5 kg, which is accelerating at 0.12 m/s² on a horizontal surface. The user initially calculated the frictional force (Ff) as 0.31 N using the equation F=ma, but misapplied the normal force by incorrectly using 1500 instead of the correct mass in kilograms. The correct coefficient of friction (µ) is determined using the formula µ = Ff / (mg), leading to a final value of 0.2 after correcting the calculations.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of frictional force calculations
  • Familiarity with normal force concepts in physics
  • Basic algebra skills for solving equations
  • Review the principles of friction in physics
  • Study the relationship between mass, weight, and normal force
  • Practice solving problems involving coefficients of friction
  • Explore advanced topics in dynamics and kinematics
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of friction and force calculations.
BlakcDahlia
A cart that weighs 1.5 kg is accelerating at .12 M/s^2 on a horizontal surface. The cart is being pulled by a weight of 50 grams. Find the coefficiant of friction.
I've been using F=ma so 1.5(.12)=.18N
the weight pulling is equal to .05kg(9.8)=.49N
.49-.18=.31N=Ff Ff=m(Fn) .31=m(1500) m (the coefficient of friction)= .0002
I don't feel like this is the right answer, can anyone see what I'm doing wrong?
Check your calculation for the normal force...Where did you get 1500 from?
I thought in Normal force was measured in grams, not kilograms. That may be where I went wrong. So the proper equation should be .31/1.5=.2? That seems pretty simple and for some reason feel like I've messed up somewhere else but if that's all that I seem to have done wrong then thanks!
Again make sure all your calculations are correct...If the Ff = .31 N and the mass of the object is 1.5 kg use the equation µmg=Ff to solve for µ. I think you understand the concepts, just make sure you are doing the algebra correctly...
Forces are measured in Newtons. Grams and kilograms are used for mass, not force.
  • · Replies 20 ·
